Old 08-08-2019, 07:03 PM   #1
kIng_kOng
kIng_kOng's Avatar
Drives: 2010 IOSS
6spd launch help
I’m curious what you 6 speed guys are 60 footing and on what size rim and tire. I have a stock clutch,600hp, 3.91’s, trailing and toe rods, lpw cover, axels, and a pinion mod. The best sixty I’ve had has been a 2.05 on a 20 inch wheel with a Mickey street comp tire. What can I do to get the sixty down? New clutch?
kIng_kOng is offline   Reply With Quote
Old 08-08-2019, 07:10 PM   #2
bkevind
bkevind's Avatar
Drives: 2013 2SS RS 1LE
I'm not a drag racer but why are you using a 20" wheel? You need more grip, more flex, more sidewall in the tire. Go down to a 15" if you can, or anything in between that and the 20, you should see some improvement. What size tire are you running on the 20?
What about the clutch makes you think it's slipping too much? If it's slipping too much when fully engaged then yeah, time for a new / upgraded clutch.
468, Mishimoto rad + oil cooler, TSP LTH
MCS 2WNR
CTSV/ZL1 front calipers/rotors + G-Loc
Forgestar CF-5 19x11
bkevind is offline   Reply With Quote
Old 08-08-2019, 07:31 PM   #3
SquawkVFR
Drives: 2010 Camaro
I’m not being a smart ass honestly. But no matter what you read here I’ll tell you what we’re doing...the best we can.
Get your RWHP and torque dialed in, get a new clutch, sticky tires and all the other goodies and try and be consistent.
Then just follow those ten speed automatics right on down the road...cause buddy, nowadays..manual transmissions are just for fun.
SquawkVFR is offline   Reply With Quote
Old 08-08-2019, 08:10 PM   #4
kIng_kOng
kIng_kOng's Avatar
Drives: 2010 IOSS
Your absolutely right. I have a small tire chassis car also. This is just that my fun street car. I’d Like to get in the 1.8x’s with the 6 speed and keep the rear brembos.
Old 08-08-2019, 08:13 PM   #5
kIng_kOng
kIng_kOng's Avatar
Drives: 2010 IOSS
It’s a 305. The clutch is not slipping but it’s either in or out. Meaning it does not come together smooth like a twin disk clutch.
Old 08-08-2019, 08:24 PM   #6
SquawkVFR
Drives: 2010 Camaro
I will say that should make big difference. I have a Monster LT1SC I love it, I’d bet that clutch will help you off the line. IF YOU GET IT, MAKE SURE YOU BREAK IT IN CORRECTLY.
Old 08-08-2019, 08:30 PM   #7
kIng_kOng
kIng_kOng's Avatar
Drives: 2010 IOSS
What was the break in process for your Monster?
Old 08-08-2019, 08:53 PM   #8
SquawkVFR
Drives: 2010 Camaro
About 500 miles of stop and go/heat cycles...it is imperative!
Old 08-09-2019, 10:57 AM   #9
2NASSTY
2NASSTY's Avatar
Drives: 2014 M6 ZL1
Try moving towards a 17 or 18" drag rim (Weld) or C5 Z06 18" rear rim. Same bolt pattern as Gen5 Camaro. May need a wheel spacer on the C5.Z rim. Switch to a true track Drag Radial. M/T Street R.
Slip the clutch at 4500-5000 rpm. Work you way up to that. ie (1000-1500, then 2000-2500, etc). Make sure you do a good 2nd gear burn out before staging.
You should able to get 1.7 - 1.8 sixty foot at 600 rwhp. Just make passes and practice and have fun with it. You can still Win races in a Manual in these heavy Pigs.
15' Ashen Gray Metallic Z/28
14' Crystal Red Tintcoat ZL1 6M, 9.62 at 150.75 MPH
12' Opulent Blue Metallic CTS-V Sedan, 10.690 at 129.60 MPH - SOLD
06' LeMans Blue Metallic Z06, 11.726 at 127.80 MPH Motor - SOLD.
96' Impala SS LTx, 11.397 at 118.10 MPH Motor, 1st stage 10.526 at 127.46 MPH
2NASSTY is offline   Reply With Quote
Old 08-09-2019, 11:02 AM   #10
zlathim
zlathim's Avatar
Drives: 2010 Camaro 2SS/RS M6
My mods are in my signature. I run 26" tall drag tires on 17" wheels. 275/40/17 M/T Street R in the rear and 26X4/17 M/T ET fronts.
I regularly run 1.7x 60' times and have a few passes in the 1.6x range.
I launch at 5,600 RPMs and try to slip the clutch as opposed to dumping it.
GPI SS2; EE E2 catch can; SP 1 7/8" LT Headers w/ hfc; FM AT 3" cat-back; CAI Cold Air Intake; AEM Wideband
Tuned by GPI
McCleod RXT; MGW flat stick; Ram Clutch slave cylinder & hydraulic adjuster
BMR cradle & diff bushings, trailing arms, toe rods & upper control arm bushings
Hotchkis sub-frame brace
Stop Tech Z-23 brakes
4.10 gears, Eaton Truetrac, LPW diff cover
Best 1/4 mile 12.073 @ 115.68 mph 3,300 ft DA
zlathim is offline   Reply With Quote
Old 08-09-2019, 11:05 AM   #11
SquawkVFR
Drives: 2010 Camaro
For what it’s worth, pound for pound we do very well from the roll.
Old 08-16-2019, 02:00 PM   #12
str8wick3d
Drives: 2011 Camaro SS
Are you preloading drivetrain? When I was 6speed car I would light first bulb then hold e-brake up and bump into the 2nd bulb. Then you slip clutch and ebrake at the same time.
str8wick3d is offline   Reply With Quote
Old 08-17-2019, 09:52 AM   #13
acammer
GPI Sales Consultant
acammer's Avatar
Drives: 2011 Camaro 2SS SGM
Bingo - preloading the driveline with the e-brake is essential to keeping these things alive. When you take out all the slack you really drop the dynamic load on everything when you release that clutch.
OP needs a better tire to have much hope of hooking up 600whp, it just depends on how committed you are. I have some 18x11 ZL1 Replica's with NT05Rs for sale.. been consistent 1.73's dead hooking. They'll go more, they're just too tall for my all motor car.
You definitely need lots of RPM and a clutch slip with a stick car. I leave between 5500 and 6000rpm, with a quick but not instant release. Helps keep her nose up the first 30'.
Got a question about a GPI product? Feel free to shoot me a message!
acammer is offline   Reply With Quote
Old 08-17-2019, 12:31 PM   #14
lemontwist
lemontwist's Avatar
Drives: 12 2SS/RS L99,11 2SS/RS LS3totaled
lemontwist is offline   Reply With Quote
