![]() Drives: 2014 1SS/RS, LS3, NPP Join Date: Feb 2019
Is a stock 1LE ride height lower than a stock 2014 SS?
I thought I’d ask the experts here.
I’m wondering if a stock 1LE is lowered by GM when compared to a stock 2014 (FE4 suspension) SS? I know I have the 1LE springs already so I’m thinking a 1LE is not any lower. I’d eventually like to add the black OEM 1LE 10”x20” squared (front) wheel setup all around with the 285/35-20 tires. However, my calculations show the stock 1LE tire sidewall height is 100mm. My stock tire sidewall height on my SS is 110mm. Question - So won’t I be INCREASING my fender gap by converting to 1LE front wheels and tires with a lower sidewall height? Or, if my 2014 SS sits the same as a 1LE then fender gap would increase by 10mm but no worse than a 1LE right? Thanks in advance guys. Last edited by Black 6.2L SS; 08-10-2019 at 08:10 PM. |
