08-11-2019, 11:38 PM | #1 |
Drives: Camaro SS 2011 L99 Join Date: Dec 2018
Advice in wheel hop and more traction
Hey guys.
I did read a post about eliminating wheel hop and getting more traction on the rear end. I did post a question on there but it’s a really old post and I don’t think folks will see it so ill post the question here! I was told that a rear sway bar will help and also something called toe..... I can’t find the details. Can anyone confirm what the toe..... is and Do I just need a sway bar and these toe.... Or anything else? Thanks
08-12-2019, 01:36 AM | #2 |
Drives: 2013 Camaro 2SS Join Date: Aug 2013
solid subframe bushings and toe links will help out the most with wheel hop.
08-12-2019, 01:43 AM | #3 | |
Is a rear sway bar worth getting? And what about a front sway bar?
08-12-2019, 02:35 AM | #4 |
Drives: 2013 Camaro SS Join Date: Feb 2017
Trailing arms and toe links is what I have. You can also add cradle bushings. Never heard anything about sway bar for drag racing.
Drag radials will give you traction. |
08-12-2019, 02:37 AM | #5 |
I'm assuming you mean drag racing
08-12-2019, 02:48 AM | #6 |
Thanks for your help.
I won’t be drag racing. I will use a throttle Controller and the guy who sells them said to get a sway bar and toe ... to get more traction!
08-12-2019, 04:48 AM | #7 |
SomeguyK
Drives: 2010 Black 2SS/RS Join Date: Nov 2014
A sway bar does nothing for straight line traction. For drag racing many disconnect or remove the rear sway bar. Like others have said, solid subframe bushings, toe arms, and maybe even add some trailing arms. These will help control wheel hop. Also, an alignment with help maximize the tire contact patch.
More to come. Last edited by Black_SS10; 08-12-2019 at 05:12 AM. |
08-12-2019, 06:26 AM | #8 | |
08-12-2019, 07:43 AM | #9 |
Drives: 2010 Camaro SS/RS Join Date: Mar 2014
It's actually the front sway bar people disconnect when drag racing. It helps transfer weight to the rear better
2010 2SS/RS
Z/28 intake, NW, FAST 102, speed engineering LT's, some exhaust, ATI -10% pulley, GM flex fuel injectors, DSX flex fuel sensor, MGW shifter, HP Tuners, some suspension work, stickers and a little weight loss. 12.63 @113.53 |
08-12-2019, 07:46 AM | #10 |
Thanks.
I am just Interested in 0-60 And 1/4 mile on the road Not gonna drag race
08-12-2019, 07:56 AM | #11 |
This is gonna sound dumb but I am very glued up with cars. I am still learning!
Regarding all the parts you guys recommended.... Are they already on the car as stock parts? And there all aftermarket upgrades? Or are they additional parts? Does a stock camaro have a rear sway bar I hope you understand what I mean!!
08-12-2019, 08:25 AM | #12 |
Drives: 2010 Black 2ss Camaro SS Join Date: May 2010
trailing arms and toe rods with sub frame bushings are a must. Now if you really want to hook....get some 17s on the back with some MT et street er's.....if you bare already lowered you will need to swap out the LCAs
ZL1 10 spokes,Dart 388,ECS Supercharger 2200x, E85 Flex Fuel sensor, Dart 388 , B&M Tranny Cooler, Vigilante 4000 Triple Disc TC,Katech Ported Heads, Texas Speed Sheet Metal Intake, ECS Big Blower Cam,ID 1700s, Fore Triple Pumps, E85,ATI Super Dampner, KW V3 Coilovers, Pfadt front and rear sway bars,Pfadt Trailing arms and toe rods,ZL1 Rear Diff, RPM 6l90e level 10 Tranny, SW Long Tubes no cats,Nick Williams Boosted 102mm TB, Dr Phil Tune,Borla Atak
08-12-2019, 08:30 AM | #13 | |
My car is already lowered but I don’t know what Lcas are! Can somebody please tell me if my stock car already has all these parts on- they they just need upgrading or are they additional parts to strengthen and support the car? Is there a rear sway bar on a stock camaro?
08-12-2019, 08:48 AM | #14 | |
Your car already has these parts you would just be upgrading them. Like mentioned already. Rear cradle bushings and trailing arms make a good first purchase. Sounds like you are doing some straight line racing and this will definitely help you off the line. They will reduce wheel hop. |
