Old 08-14-2019, 04:48 PM   #1
Johndavidson1223
Drives: 2011 Camaro SS
Ignition Coil Code and misfires
So lately I’ve been getting a ignition coil code for Cylinder 5. After having an annoying misfire i changed the spark plugs, ignition coils, and cleaned my injectors. But the code has yet to go away. Has anyone else had these problems and is there any tips someone could give me? Thanks
Johndavidson1223 is offline   Reply With Quote
Old 09-05-2019, 01:03 AM   #2
Gordy87
Gordy87's Avatar
Drives: 2010 Camaro SS
Is it on cyl 5 every time? Have you pulled valve cover and inspected for broken spring or damaged rocker?
Gordy87 is offline   Reply With Quote
Old 09-06-2019, 03:36 PM   #3
jrice91
Drives: 2010 Chevy Camaro SS V8 (6.2)
Im having this same issue... My 2010 SS started with the service stabilitrak msg then it started misfiring, throwing the code for spark plugs and ignition coil assistance...changed those and it drove fine for half an hour and did the exact same thing plus #5 injector this time....changed everything plus the injector AGAIN and I’m still getting the same result....HELP US
jrice91 is offline   Reply With Quote
Old 09-08-2019, 09:20 AM   #4
Gordy87
Gordy87's Avatar
Either of you running LTH? What kind of mods done on car?
ignition coil, misfire
