![]() Drives: 2010 Camaro SS A6 Join Date: Oct 2018
Cutting off the roller skates
Hey all. I just went to have 4 race star rims installed. 18X10.5 rear and 18X8.5 front. Discount tire pointed out to me that the rims won't fit on the front. I saw why, and remembered something about cutting off the roller skates. They had never heard of this and said it's not recommended.
My question is, can I cut these off and have no worries/issues with braking during normal/aggressive driving and of course drag racing? Secondly, if it is safe to do this, how do you do it? Hacksaw or reciprocating saw? |
![]() Drives: 2011 Camaro SS Join Date: Feb 2017
Yes, it’s safe to cut them off. Only on there to fix brake noise
MRR M228 Wheels, Circle D 3200 Stall, 3.91 Gear, Texas Speed VVT 3.2 Cam, CHE Rocker Arm Bushings, Texas Speed Headers, No Cats |
![]() Drives: 2010 Camaro 2SS/RS M6 Join Date: May 2009
I used a 4" cut off wheel on an angle grinder. The hacksaw will work fine too.
GPI SS2; EE E2 catch can; SP 1 7/8" LT Headers w/ hfc; FM AT 3" cat-back; CAI Cold Air Intake; AEM Wideband
Tuned by GPI McCleod RXT; MGW flat stick; Ram Clutch slave cylinder & hydraulic adjuster BMR cradle & diff bushings, trailing arms, toe rods & upper control arm bushings Hotchkis sub-frame brace Stop Tech Z-23 brakes 4.10 gears, Eaton Truetrac, LPW diff cover Best 1/4 mile 12.073 @ 115.68 mph 3,300 ft DA |
Hey all. I have an electric handheld grinder with I believe a 4 inch wheel. I would imagine that this would cut off the roller skates quicker/easier than a reciprocating saw. Would you agree?
#5 | |
Otherwise, I'd hacksaw them off before I cut them with a grinding wheel. YMMV
#6 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2011 1SS/RS IBM Camaro Join Date: Jan 2011
Just go to Harbor Freight and get the cutting wheels. I used them and worked real good.
#7 |
Drives: 2013 Sparkly Red One Join Date: Dec 2018
Just buy the AC Delco replacement pads without the roller skates, $40.
#8 |
![]() Drives: 2013 Black camaro ss Join Date: Jan 2017
I cut mine off no issues with a grinder.
#9 |
Metal cut off disk on a hand held 4” grinder is the best way! Then switch to a grind wheel to smooth the rough edges. Then use a little extreme temp paint and a little artist brush to put a little paint on the bare steel. I did my fronts with 17” skinny’s and used this method on my Brembo pads/ skates. Just take your time because shit gets hot quick when cutting and grinding the pads. Make sure you take the pads off the calipers so you don’t accidentally nab something else other then the pads. Honestly after doing mine and the pads make no noise I think the skates are pointless and you’ll even shave a small amount of weight off without them.
Car mods: never enough!
#10 |
Thanks everybody. I picked up a metal cut off disc today to use in place of the metal grinding disc.
Getting the front tires/rims put on Friday afternoon if I don't mess something up!!!
#11 |
Word to the wise: If you remove the grinding wheel and it doesn't look like the cutting wheel will fit on the little base piece, remove the base piece and flip it over. Even on the cheaper HF grinders that mounting piece is reversible to fit more than just one application. I hope this makes sense.
#12 |
Thanks Zlathim. I will check this out.
