Old 08-18-2019, 09:31 AM   #1
teeroy97
teeroy97's Avatar
Drives: 2011 Camaro 2TTSS
New fuel pump & injectors needed?
Going to wade in and get an AGP TT setup. 2011 Camaro SS, Manual, with stainless headers & pipes, catch-can, cold air intake, and a viper tune. No plans to do a cam right now.
After reading up on this, wondering if I need to get upgraded injectors and/or upgraded fuel pump, or one and not the other. Since the engine is still stock, I was thinking I could maybe get away with the stock SS injectors, but I don’t know.
Thanks in advance for all your advice!
teeroy97 is offline   Reply With Quote
Old 08-18-2019, 10:50 AM   #2
sscamaro
Drives: 2010 2SS, 2017 Silverado LTZ
If it's stock. you don't need any of them.
sscamaro is offline   Reply With Quote
Old 08-18-2019, 10:53 AM   #3
teeroy97
teeroy97's Avatar
Thanks! That’s what I was hoping.
Old 08-18-2019, 05:20 PM   #4
Moreair1
Moreair1's Avatar
Drives: 2011 ss convertible
If your having a agp kit installed you will need at least a bap and 850cc injectors I would recommend at least a zl1 pump with 1k injectors, sale the headers if there lt's and intake to help pay to upgrade fueling if money is short
Cai intake and a few other mods😎
Moreair1 is offline   Reply With Quote
Old 08-18-2019, 10:08 PM   #5
gunchamp
gunchamp's Avatar
Drives: 15 Camaro SS
A turbo will absolutely require you to upgrade your fuel system. Injectors and pump. Imo, dont band aide it. Just go in and do it right the first time so you dont have to redo it when you add more power. And you lost likely will. I researched the hell out of it and you are much better off to do it right the first time
gunchamp is offline   Reply With Quote
Old 08-19-2019, 07:38 AM   #6
jeff657756
Drives: 2014 SS 1LE
At least do an aux pump and 1000cc injectors and run e85 if you have it near you. Twin pump return setup if you have the money. Do it once and forget about it.
jeff657756 is offline   Reply With Quote
Old 08-19-2019, 07:48 AM   #7
gm2376
gm2376's Avatar
Drives: 2010 Black 2ss Camaro SS
you will absolutely need bigger injectors and a BAP or zl1 pump at least.
Apex VS-5RS Forged Wheels,Dart 388,ECS Supercharger 2200x, E85 Flex Fuel sensor, Dart 388 , B&M Tranny Cooler, Vigilante 4000 Triple Disc TC,Katech Ported Heads, Texas Speed Sheet Metal Intake, ECS Big Blower Cam,ID 1700s, Fore Triple Pumps, E85,ATI Super Dampner, KW V3 Coilovers, Pfadt front and rear sway bars,Pfadt Trailing arms and toe rods,ZL1 Rear Diff, RPM 6l90e level 10 Tranny, SW Long Tubes no cats,Nick Williams Boosted 103mm TB, Dr Phil Tune,Borla Atak...955rwhp/967rwtq
gm2376 is offline   Reply With Quote
Old 08-19-2019, 09:32 PM   #8
teeroy97
teeroy97's Avatar
Thanks that is what I am finding out. Going to get AGP's pump with flexfuel sensors and the 1000cc injectors.
Old 08-19-2019, 09:34 PM   #9
teeroy97
teeroy97's Avatar
yessir. You got to give it the fuel in order to make the power. Going to use E85 -- it's everywhere in Houston...
Old 08-20-2019, 07:42 AM   #10
gm2376
gm2376's Avatar
for boost and e85, I wouldn't go lower than 1300cc injectors and twin pumps.
Old 08-20-2019, 08:30 AM   #11
teeroy97
teeroy97's Avatar
Ok might as well while I’m at it. So I guess I will get the 1300 cc and agp’s twin pump
Old 08-20-2019, 08:52 AM   #12
NoDakZ/28
NoDakZ/28's Avatar
Drives: 2014 Z/28 CTF
What are your HP goals with this car/setup? I do not think he shouldnt buy 1300cc injectors if he doesn't plan on big power. I'm on FIC 1000's and its holding my huron setup close to 800hp with a 88% duty cycle on my fore twin system. No need to spend unnecessary money when he will need other parts to support.
2014 1LE - Sold
2014 Z/28 #99008 CTF SIM
NoDakZ/28 is offline   Reply With Quote
Old 08-20-2019, 08:58 AM   #13
teeroy97
teeroy97's Avatar
I’m looking for 700-800 whp. So, will 1000cc injectors be adequate?
Old 08-20-2019, 09:05 AM   #14
Juiced1
Drives: 2012 2SS CAMARO 45th
I agree you should always set a goal and work around that power number. I do think it's better to over buy on a fuel system however. I'd rather buy an injector I can grow into rather then something I will grow out of. Goals seems to change once you reach them.
OP what are you looking to put down with your set up? We have tons of options for both pumps and injectors.
Juiced1 is offline   Reply With Quote
agp, fuel injector, fuel pump, twin turbo
