Old 08-19-2019, 01:16 AM   #1
tlamb2
WHPLSH
tlamb2's Avatar
Drives: 2010 SS Maggie,ARH,Meth, BTR stg2
Hotchkis Chassis brace with stock Cradle bushings?
So I have the Hotchkis Max Chassis brace but my rear end still moves all over the place, 600RWHP so I am going to change the cradle bushings. Someone told me solid bushings do not work well with the brace? Does anyone have any input on this thanks?
tlamb2 is offline   Reply With Quote
Old 08-19-2019, 05:55 AM   #2
KillboyPowerhead
Drives: 2015 Z/22
JusticePete always suggested upgrading the cradle bushings and not bothering with the chassis brace at all. Maybe remove the brace when you install the bushings and see how the car feels, then throw the brace back on and see how it feels. If you don't notice much difference with the brace and the bushings then remove the brace and save yourself a few pounds.
What other suspension mods do you have?
KillboyPowerhead is offline   Reply With Quote
Old 08-19-2019, 06:36 AM   #3
Scott@Bjorn3D
I have the same brace and bushing and no problems.
Scott@Bjorn3D is offline   Reply With Quote
Old 08-19-2019, 10:12 AM   #4
hammdo
'It's an experiment'
hammdo's Avatar
Ditto brace and solid bushings here. The brace adds protection also for my DSX aux e85 kit too...
-Don
747 RWHP 794 RWTQ
Old 08-19-2019, 12:31 PM   #5
Aries240SS
Drives: 2011 1SS RS Camaro, 1995 LSX 240SX
Brace and bushings here too. The brace gives the car a lot more rigidity even once the bushings are in. I read the same and tried it without and you could still feel a little flex back there when launching or cornering. Brace back on and all is well again.
2011 Camaro 1SS
Whipple Supercharged 1150/1100 @ 24psi - Removed blower and went Turbo
Huron Speed T6 1135/1070 @ 20psi so far. 15 more PSI loading...
Aries240SS is offline   Reply With Quote
Old 08-20-2019, 03:28 AM   #6
tlamb2
WHPLSH
tlamb2's Avatar
Ok so I will go with some solid bushings thanks for the input
Old 08-20-2019, 12:54 PM   #7
PostNup
CAR-DASHIAN
Drives: 2015 Ashen Gray Metallic 2SS/RS L99
Go with the Pegasus CNC Billets - works of art, work perfectly and half the price of others
PERFORMANCE: ColdAirInductions CAI, ADM Race Scoop, Cordes Performance Racing Ported TB/IM/Custom VVT Cam, WFO Milled Heads, Stainless Power 1 7/8" LT/3" HFCs, JBA 3" Comp. Cat-Back, Taylor 10.4mm Plug Wires, Tim King Performance Stage 3 6L80, Circle D Billet 3600 Stall, Nic D ECM/TCM Tune, - 458rwhp/413rwtq (prior to PIM), Forgestar F14 (F)18" / (R)17" Rims.
SUSPENSION: Z/28 Rear UCA Bushings, Carlyle Racing LCA/TA, BMR Adj. Toe Rods/Xtreme Anti-Roll Bar, Justice Pete Castor Locks/Radius Rod Inserts, Pegasus Billet Rear Cradle Bushings, Mickey Thompson Street SS II 305/45/17 tires.
PostNup is offline   Reply With Quote
Old 08-21-2019, 02:09 AM   #8
tlamb2
WHPLSH
tlamb2's Avatar
Pegasus is out of business, The choice for solid aluminum is slim, Thanks
Old 08-21-2019, 11:54 AM   #9
CamaroFred
CamaroFred's Avatar
Drives: Miss Con Ception
I installed Pedders inserts when my Camaro was stock. Took out the handling wiggles. I'm up to 410 WHP and still don't have any wheel hop.
With 600 at the wheels they might not cure all the hop, but they have to be better than nothing. Much easier to install than solids.
2011 1SS/RS LS3 CGM
CamaroFred is offline   Reply With Quote
Old 08-22-2019, 03:33 AM   #10
tlamb2
WHPLSH
tlamb2's Avatar
That is true anything is better than the stock ones Thanks for your input
Old 08-22-2019, 06:22 PM   #11
Avalnch
Avalnch's Avatar
Drives: Rally Yellow Camaro+Avalanche
Have you replaced your trailing arms and toe-links?
Vengeance Kaotik Cam, C.A.I., ARH LT, Pypes Cat Back, ZL1 Shifter+2012LS3VERT bushing, Quantum Brake Ducts, JDP Tow Hook Scorch Yellow Trim Kit, Shark Fin, AAC DRLs+ABLs+SMDs, ZTA Rear Spoiler, R.Y. 1LE Splitter. Pfadt coilovers, camber plates, trailing arms, Pegasus Solid Subframe. Pedders ZL1 barz, radius arm & steering rack bushings. BMR adjustable toe-rods. Hotchkis Max Chassis Brace. ZL1 GMPP Driveline Upgrade. TurnOne P/S pump. CTS-V 6 pistons.
447 HP @ 6180 RPM / 418 TQ @ 5100 RPM
Avalnch is offline   Reply With Quote
Old 08-23-2019, 12:37 AM   #12
tlamb2
WHPLSH
tlamb2's Avatar
Yes trailing arms and toe links replaced along with springs and sways.
