08-19-2019, 03:24 PM | #1 |
Drives: 2019 ZL1 A10 in White Summit Join Date: Apr 2015
ZL1 Addons front splash guard installation clip...
Hi,
i just received my ZL1 addons front splashguard. I wanted to go with the ACS one but I dont want to drill holes on my inner fender... not on a car slightly more expensive than my annual salary... ZL1 Addons states that they used existing OEM mounting point, that was the selling feature for me. When I opened the package and looked at the instruction, it comes with "specially designed" clip to offer a stronger installation but the freakin clip are METAL and they are to be slided in the inside of your fender with pointy edges that will dig into the surface they are slided on to prevent loosing up. Digging means it will scratch inside the fender and expose bare metal so it will eventually rust because this is where all water will go when using the car in the rain. Question is do I really need the clips installed or just the lower mounting hole with the plastic pin and the 3M VHB tape will be enough? It seems the first version of the design did not used any clip..... I am not going to use those clips, bad engineering, I will return these if the tape is not strong enough..... Thanks |
08-19-2019, 04:00 PM | #2 |
Drives: 2018 ZL1 Join Date: Dec 2018
I used the clip.... also added a secondary strip of tape as well. I'm sure you could ditch the clip with more tape. ZL1addons are a great company. First week I had them the wife nailed a rabbit an broke one, asked the company to buy just a single guard and they sent me a whole kit!
2018 A10 ZL1
2020 Can Am X3 XRS turbo RR 2019 TRD PRO Tundra (wifes) 2015 TRD Tundra (traded) 2014 Subaru WRX (traded) 2000 Z28 (sold) 1970 GMC 1500 (stolen) 2017 YXZ1000 (sold) |
08-19-2019, 04:59 PM | #3 |
I am tweaking them on 1 side I have smoothed out both side teeth so it is not going to bite inside my fender, and I left them on the side to bite on the plastic of the splash guard.
They should not move and stay there with only the ouside bitten on the splashguard. Call me OCD but I will put a coat of 3M transparent shipping tape on the inside of the clip so at least its going to be plastic rubbing on metal instead of metal to metal.... I think its going to work out.... |
08-19-2019, 06:21 PM | #4 | |
Drives: 2019 Camaro ZL1 1LE Join Date: Jun 2019
08-19-2019, 09:06 PM | #5 |
Drives: 2016 Challenger Hellcat, 2018 ZL1LE Join Date: Dec 2009
I had the same thought when I installed mine. I did it anyway, I’m surprised my OCD allowed me to. Hahaha.
Too late now for me to worry about it.
2016 Challenger Hellcat /B5 blue/Sepia interior/Brass Monkey Wheels/
2018 ZL1 1LE/Red hot 2019 Shellby GT 350R/ Oxford white/ Matte Black Stripes/ Carbon Fiber Dash/ Electronics Package #413 |
08-20-2019, 09:21 PM | #6 |
2019 White ZL1 A10
2007 Black HUMMER H2 2018 KIA CADENZA LIMITED --> Aparently rare AF in Canada |
08-21-2019, 12:46 PM | #7 |
Drives: 2013 C6Z06 Join Date: Nov 2016
I have the early ones installed on my car with no clip and haven't had any issues
08-21-2019, 01:03 PM | #8 |
Looks good! Kind of wish they were a little wider. Anyone have any experience with these on a ZLE?
08-21-2019, 11:21 PM | #9 |
Drives: '19 ZL1 1LE A10 ShadowGrayMetallic Join Date: Mar 2019
08-21-2019, 11:48 PM | #10 |
Drives: 2018 ZL1 1LE Join Date: Jul 2009
They do a good job on a zle. Not too difficult to install...maybe an hour without lifting the car. At first i wished they were a little wider, but currently they seem to be saving the rockers and quarter panels which were annihilated on my white ss i had before the zle. Couple the rock guards with ppf in high impact areas and street tires, my paint is thanking me every day. Lol.
08-22-2019, 07:09 AM | #11 | |
08-22-2019, 09:42 AM | #12 | |
Drives: 2019 Camaro ZL1 Join Date: May 2019
08-22-2019, 02:21 PM | #13 |
Drives: 2018 Camaro ZL1 Join Date: Aug 2018
No. They adhere to the car. The front is a bit easier than the rear since you can turn the wheel.
Shouldn't take an hour unless you give the entire car a wash. Just a simple wash of the area where it's going and less than 30 minutes if you're doing front and rear. Maybe even less than 20 minutes |
08-22-2019, 10:47 PM | #14 | |
