Old 08-20-2019, 10:03 AM   #1
thegreatwhite
Drives: 2014 SS
whats wrong with my camaro
im hoping this is a battery issue but im interested to see if anyone has experienced something like this with their car.
i have a 2014 2SS RS, manual. used to be a daily driver but now for about the last year and a half it mostly stays in the garage because i have another car i drive everyday. i take the camaro out once in a while, try to run it every 1-2 months to keep everything normal. well the last time i really drove it was maybe late may or early june.
a couple weeks ago i went to start it and it would not start. some of the interior lights would come on but not everything, it would not crank and the little yellow check engine light was on. idk what the problem was but since i had not started it in a couple months i hoped it was just a dead battery. i jumped it, it started fine, drove it around for like 30 minutes. turned it off and on a few times and everything was good. went back home parked it an that was it.
i go to start it again last weekend and the same problem happens, some lights come on but not all, starter wont crank. this time when i jumped it it had to crank alot to get started. like more than iv ever heard it have to. then once it got running the motor was running very roughly an weak it felt like for a minute or two. on top of that now i was getting a "service stabilitrak" and service something else message on my screen. also when i revd the gas the RPM on the dash did not move at all. i did not drive it at all cause i didnt know what would happen on the road. i let it run for about 10 minutes. turned it off and tried to turn it on again and it started but had to crank quite a bit again to get started.
its been a little over 5 years since i got the car and its sat most of the last year, do i just need new batteries? or is this a bigger problem. anyone have a similar experience?
thegreatwhite is offline   Reply With Quote
Old 08-20-2019, 10:08 AM   #2
SSkat
SSkat's Avatar
Drives: 2010 Camaro 2SS
Start with the battery
SSkat is offline   Reply With Quote
Old 08-20-2019, 10:08 AM   #3
Venomcustom
Hard to want.
Venomcustom's Avatar
Drives: 2020 red hot 1SS 1LE
I would change the battery, spark plugs and possibly plug wires. Then see how it is.
Venomcustom is offline   Reply With Quote
Old 08-20-2019, 10:18 AM   #4
SlingShot
SlingShot's Avatar
Drives: 2012 ZL1 - #670
Battery for sure seeing it's 5 years old. Get a new one along with a tender to keep it going. If I let any of my cars go longer than two weeks without running, the battery will be dead. Last year I had to replace three batteries at around $250 a pop. Being yours is a 14, there may be a transport mode you can put it in.
There is no confirmed Transport Mode for thy 5th Gen only the 6th Gen
Old 08-20-2019, 11:54 AM   #5
Welker2
Ret AF, cancer survivor
Welker2's Avatar
Don't believe there is anything wrong with your Camaro; your battery is over 5 years old and you are letting it sit for weeks at a time. With all the electronics on vehicles these days, if you let them sit for long periods of time, the battery will slowly drain.
First, given your battery is 5 years old and has been drained a couple of times, I would replace it.
Second, I would get a battery tender/maintainer. I had a similar problem if I let either of my vehicles sit for over a week or so (being retired, this happens frequently). Once I started using the maintainers, no more issues. I personally like the Deltran Battery Tender series as they are relatively cheap, work well and can be bought at just about any auto parts store or on line from Amazon or other sources. I currently use the Battery Tender 800 on my Corvette and Battery Tender Plus on my Camaro. Both have the quick connect harnesses that make connecting/disconnecting a snap. That being said, there are a lot of good tenders/maintainers out there.
Old 08-20-2019, 12:04 PM   #6
Juiced1
Drives: 2012 2SS CAMARO 45th
Either put your battery on a charger or get a new battery. It really sounds like that is the issue.
Juiced1 is offline   Reply With Quote
Old 08-20-2019, 05:09 PM   #7
scoob7276
Drives: 2013 Camaro 2SS Convertible
As far as it not turning over at all, start with the battery like everyone else has said. BUT...the fact that it took a while to start and then running poorly, I would venture to say it is the gas. You never said anything about filling it with fuel, adding fuel stabilizer or anything of the such. Gas will go bad, especially over 12 months, or possibly longer, worth of time. I would either drain the gas, and fill with new(adding fuel stabilizer), or fill it up from where it is and run the entire tank out. Then refill and add fuel stabilizer before you park it again.
scoob7276 is offline   Reply With Quote
Old 08-20-2019, 05:14 PM   #8
Rock-It Man
376 cubic inches of fun
Rock-It Man's Avatar
Drives: 2023 Camaro ZL1 A10
If you use the car so little, you should be hooking up to a battery tender.
So first get a new battery (you're due after 5 years because of disuse) and second, start using a battery tender. That way the new battery will comfortably last more than 5 years.
Rock-It Man is offline   Reply With Quote
Old 08-20-2019, 05:34 PM   #9
15RS2NV
Ponies are for girls
15RS2NV's Avatar
Drives: 2015 RS LFX Red Hot A6
New battery and use a trickle charger
Like explained above, an older battery sitting for weeks/months at a time will slowly drain your battery. In my opinion, you'll need a new battery, a trickle charger (keep it charged the week(s) you don't drive it), and make sure you don't have pack rats under your hood. Your stabilitrac codes are just because you battery is so dead, it's lost it's memory. If you have a new battery, it'll learn again.
In your area, 5-8 years is life of a car battery. Letting it sit will decrease the life so being 5 almost 6 years you're due for a new one. Here in Tucson, batteries last 2-3 years because of our extreme heat during the summers.
H&R 1.8/1.7” drop, Overkill 80mm + intake ported by AFS, 1" insulator MACE, Accel Super Coils, THR cai, JET MAF sensor, Hurst shifter handle, GPP strut tower brace, CI ice cube tray hood vents (functional) @SemperFiCamaro
15RS2NV is offline   Reply With Quote
Old 08-20-2019, 05:41 PM   #10
thegreatwhite
Drives: 2014 SS
thanks. this was the answer i was hoping for that it was the battery and not a worse problem. thanks for the help.
Old 08-20-2019, 05:42 PM   #11
thegreatwhite
Drives: 2014 SS
with that being said lets take it a step further. what car batteries do you guys use for your camaros.
Old 08-20-2019, 06:41 PM   #12
zlathim
zlathim's Avatar
Drives: 2010 Camaro 2SS/RS M6
I installed whatever it was that was available in the correct size at the parts store. Works fine. If you want to go all fancy, there are plenty of premium batteries to chose from. I've always wanted to try an Optima, but never have.
GPI SS2; EE E2 catch can; SP 1 7/8" LT Headers w/ hfc; FM AT 3" cat-back; CAI Cold Air Intake; AEM Wideband
Tuned by GPI
McCleod RXT; MGW flat stick; Ram Clutch slave cylinder & hydraulic adjuster
BMR cradle & diff bushings, trailing arms, toe rods & upper control arm bushings
Hotchkis sub-frame brace
Stop Tech Z-23 brakes
4.10 gears, Eaton Truetrac, LPW diff cover
Best 1/4 mile 12.073 @ 115.68 mph 3,300 ft DA
zlathim is offline   Reply With Quote
Old 08-20-2019, 06:49 PM   #13
kmarshall2121
kmarshall2121's Avatar
Drives: 2012 45th Anniversary Edition
Throwing any codes beside the engine light? My Avalanche hardly ever gets driven, decided to a while back - engine light on - then blinking - found out a damn family of mice had been chewing up wires. in fact, one was dead, with a sparkplug wire in his jaw... replaced all the bad wiring, and bam! shes got power, and no more issues (unless gas drained to the cats, then i have that to deal with before a smog check) - good luck!
kmarshall2121 is offline   Reply With Quote
Old 08-20-2019, 09:02 PM   #14
Rock-It Man
AC Delco, the OEM battery.
I took care of mine and it was still OK after 7 seasons when I replaced it as a precaution. Now on season 10.
The car has never sat for more than 2 weeks without a battery tender, and it is hibernating on the tender for 6 months even year.
