Old 08-21-2019, 05:23 PM   #1
Scott S
Scott S
Drives: 2011 Camaro 2SS
MGW or Hurst?
Looking for a shifter. Let me know your opinions!
769HP/699 Torque LS3 heads ported and polished with BTR Spring kit & Trunion upgrade, LSA supercharger ported by DC Porting, 102MM throttle Body, 2.40 pulley upper pulley, Innovators West 10% Overdrive lower, BTR Stage 3 PDS Blower Cam, Mighty Mouse Catch Can, SMG Flex Fuel kit, SMG Aux Fuel System, FIC 1000 Injectors, MGW Flat Stick Shifter, RPM Stage Vll Transmission, McLeod RXT clutch, ARH 1 7/8 Headers, 3" X-pipe with Borla S-Type mufflers, ZL1 3:23 rear diff and Axles, 1LE suspension. Bmr Bushings in back. TUNING AND SPECIAL ALIGNMENT BY CARL@Twincitiesperformance
Scott S is offline   Reply With Quote
Old 08-21-2019, 07:02 PM   #2
SquawkVFR
Drives: 2010 Camaro
SquawkVFR is offline   Reply With Quote
Old 08-21-2019, 07:12 PM   #3
Rons1le
Rons1le's Avatar
Drives: 2015 Camaro 2SS RS 1LE AGM
MGW ftw imo
Sent from my SM-G960U using Tapatalk
2015 2SS RS 1LE NPP/w Kooks headers, Procharged, ID1050X injectors, Katech belt tensioner, Mighty Mouse Catch Can, BMR subframe connectors, Matco driveshaft loop, AEM Wideband/Boost/Fuel gauges , Z/28 Splitter and Spoiler/w Wicker bill, Power Stop rotors and brake pads, MRR Z/28 Rep Wheels 20" w/p zeros 285 fronts and 305 rears, ZL1 addons Rock guards and Tow hook, Rear window louvers, Flags on the quarter windows and the moonroof, Billet aluminum door handles.
Rons1le is offline   Reply With Quote
Old 08-21-2019, 07:14 PM   #4
1911 1LE
Drives: 2015 SW 2SS 1LE
Originally Posted by SquawkVFR View Post
Maggie 2650 @ 18psi/ 75mm 10 rib/ Dual alky nozzles/ Roto-fab/ ARH 2" Lt's/ GT-12 cam/ ZL1 3.23 Conv./MGW/RPS triple carbon clutch/RSG tranny upgrage/Pedders Ex. XA w/ remote cans and a lot of other crap 897/8??@tires
1911 1LE is offline   Reply With Quote
Old 08-21-2019, 07:20 PM   #5
CamaroDreams76
Tri-County Camaro SWFL
CamaroDreams76's Avatar
Drives: 2013 IOM 2SS/RS/1LE
Is this a serious question?
Serious note. MGW all the way. I thought the OEM 1LE shifter was pretty good until I installed the MGW.
Took a 2013 SS on a test drive with the Hurst option. What a notchy pos. Ordered my 1LE, loved the shifter but the MGW is miles better.
Old 08-21-2019, 07:40 PM   #6
Wizard1183
Wizard1183's Avatar
Drives: ABM SS2/RS M6
Send a message via Yahoo to Wizard1183
Hurst is not even in the same universe as MGW. This shouldn’t even be a valid question to be honest. It’s MGW or nothing. Hurst? You’re paying for just a name of a classic product. Quality has gone down the toilet.
Life is short, drive it like you stole it!
Wizard1183 is offline   Reply With Quote
Old 08-21-2019, 08:50 PM   #7
Iron Lung Jimmy
Drives: Iron Lung, Jimmy
I like my Hurst a lot. It has sort of a rifle bolt feel when you shift which I like but some people do not.
Hurst advantages: Rifle bolt feel to shifts, easy to install, looks badass.
Hurst disadvantage: Rifle bolt feel to shifts.
MGW advantage: Smoother shifts
MGW disadvantages: Not easy to install, looks meh.
Iron Lung Jimmy is offline   Reply With Quote
Old 08-21-2019, 10:43 PM   #8
SquawkVFR
Drives: 2010 Camaro
Jimmy. You forgot Hurst has a 38% throw and MGW only has a 33% throw.
Old 08-22-2019, 12:55 AM   #9
SS 310H55A
Drives: 2014 Camaro SS
Mgw is the way to go. Took me a little more than an hour to install. Install is actually not that bad.
2014 SS | MGW Flat Stick shifter | Raceseng Slammer shift knob | Z/28 spoiler and grill
SS 310H55A is offline   Reply With Quote
Old 08-22-2019, 06:11 AM   #10
CamaroDreams76
the MGW has spring assisted 2-3rd shifts for faster shifts and spring assisted 5-4 for smoother downshift. Also MGW is an entire shifter assembly not just the shifter shaft.
Old 08-22-2019, 07:08 AM   #11
Wizard1183
Wizard1183's Avatar
I’d say only negative of MGW is road noise cause the shift assembly is not as huge as factory. Hurst, you’re basically changing out the shift. So if notchy? It’s cause factory is not hy
Old 08-22-2019, 11:07 AM   #12
Scott S
Scott S
Thanks for the input guys! Looks like I will go MGW. Anyone have one they want to sell?
Old 08-22-2019, 11:37 AM   #13
SquawkVFR
Drives: 2010 Camaro
I’m in a real smart ass mood today so seeing how great they are..I’m gonna go with Yeah, MGW.
Old 08-22-2019, 11:51 AM   #14
Spec
Drives: 2010 Camaro 1SS LS3
Very happy with my HURST stick. It felt a bit notchier than stock after I installed it... but it got smooth as butter after I installed a heavy knob (abrams). Also, the Hurst is prettier than the MGW in my book... I'm good with Hurst.
Spec is offline   Reply With Quote
