Old 08-22-2019, 11:09 PM   #1
rfs
Drives: 2010 ss camaro
Long Tube Headers (catless) + borla atak axle back
Anyone have this combo? I'd love to hear it if so. All the videos I find are of LT's with atak catback.
Also is the sound noticeably different between the catback vs axle back? I don't necessarily expect any gains as far as performance goes. I have LT's now with the gm factory performance exhaust, which apparently an unbranded borla touring axle back, and its just not enough for me.
Id love to hear some input/advice, Im currently finishing up my Masters degree so a catback is just out of my budget tbh
rfs is offline   Reply With Quote
Old 08-23-2019, 01:18 PM   #2
InFiD3ViL
InFiD3ViL's Avatar
You don't really need to have a catback if sound is really what you are after. You can piece together your own. Sure, it's not as satisfying as installing a full, engineered catback into the car, but it will sound nearly the same and produce almost identical performance results...which is very little.
Get a good X pipe to go with your axle back and you should be set since you already have the long tubes.
I have TSP long tubes, catless off-road pipes going into a Summit Racing X pipe. I used my stock piping after the X pipe which goes into my Flowmaster Outlaw Axle back. It sounds great and was substantially cheaper than a full cat back. Only big difference is that I am still running 2.5 inch pipes. If you go with a full cat back you have the option of searching for a system that uses full 3 inch pipes from the collectors back. But unless you are pushing big power, you will never miss it.
So yes, it will almost certainly sound the same to you. If budget is a concern, go with the axle back.
Old 08-23-2019, 10:03 PM   #3
perschkeb
perschkeb's Avatar
Drives: 2010 SS 6spd Aqua Blue
I've got a brand new borla mid pipe kit for half the price as new and I live in Florida panhandle if you're interested in doing the full cat back system
perschkeb is offline   Reply With Quote
atak, borla
