Old 08-24-2019, 07:28 AM   #1
AustexaSS
Build Date - Dec 08, 2014
AustexaSS's Avatar
Drives: 2015 Z/28, #1007, Black A/C Stereo
Camber Plate Manufactures
For those of you looking for camber plate manufacturers here are some options still in production:
https://www.detroitspeed.com
https://vorshlag-store.com
There are probably others but these are the first two that came to mind.
Hope this helps!
AustexaSS is offline   Reply With Quote
Old 08-24-2019, 10:21 AM   #2
olblue75
olblue75's Avatar
Drives: 2010 2SS/RS
I asked this very question thanks for the post, new about DSE an forgot about Vorshlags
Orange Krush II
Old 08-24-2019, 12:01 PM   #3
SS Performance
SS Performance's Avatar
Drives: 02 Camaro B4C
Ground Control makes them as well, no modifications required.
A man's garage is his castle
1969 Camaro SS
1970 Camaro SS
2002 Camaro B4C
2014 Camaro SS Dedicated Track Car
2015 Camaro 1SS 1LE
2008 HHR SS
1996 Silverado Crew Cab Long Bed Dual Rear Wheel
SS Performance is offline   Reply With Quote
Old 08-25-2019, 10:54 AM   #4
olblue75
olblue75's Avatar
Drives: 2010 2SS/RS
https://groundcontrolstore.com/colle...-camber-plates
500 bucks
https://vorshlag-store.com/collectio...ates-perches-1
529
https://www.detroitspeed.com/2010-20...-camaro-030322
500
An thought Hendrix Engineering was making the or selling the Pegasus camber plates. An Gen5Diy has the Moreno plates but are sold out.
Orange Krush II
Old 08-25-2019, 11:21 AM   #5
j o n
j o n's Avatar
Drives: 2015 Z/28 #0058
DSE is only for jri or their coilovers
https://www.detroitspeed.com/front-c...-camaro-030322
Current:
- '15 Z/28 #0058 | White | A/C | Speakers | Michelin PS4S 305/30/19's
- '22 Ridgeline RTL | White | Ebony, '22 CR-V EX-L Hybrid | White | Ebony
Sold:
- '15 Z/28 #0048 | White | A/C | Speakers | Michelin PS4S 305/30/19's
https://www.instagram.com/__jon__athan__/
j o n is offline   Reply With Quote
Old 08-25-2019, 12:15 PM   #6
olblue75
olblue75's Avatar
Drives: 2010 2SS/RS
Dag Gummit
Well dammit
Orange Krush II
Old 08-25-2019, 06:33 PM   #7
SS Performance
When I was looking for Caster Camber Plates Ground Contro was the only one that didn't require modifications and worked with stock struts/springs.
1969 Camaro SS
1970 Camaro SS
2002 Camaro B4C
2015 Camaro 1SS 1LE
2008 HHR SS
Old 08-26-2019, 01:55 PM   #8
VOIT
VOIT's Avatar
Drives: Z/28
Ground Control says,
OEM Camaro upper spring isolator must be transferred onto camber plates when using factory diameter springs. *Ride height will be raised approximately 10mm when using factory diameter springs*.
Looking into Vorshlag
VOIT is offline   Reply With Quote
Old 08-26-2019, 02:10 PM   #9
AustexaSS
AustexaSS's Avatar
Vorshlag install info:
https://youtu.be/SZkxNonyt7c
https://youtu.be/FQ8FBW7EKWU
