Old 08-26-2019, 12:30 PM   #1
Lacpac
Lacpac's Avatar
Drives: 2012 Crystal Red Tintcoat RS
Switching out HID Headlights for LED on RS 2012
Has anyone replaced their factory HID bulbs with LED?
It looks like there are some companies that make direct plug & play as long as you bypass the ballast. Easy? Difficult? Does this mess with any error codes?
Anyone find fanless LEDs?
Lacpac is offline   Reply With Quote
Old 08-26-2019, 05:52 PM   #2
shibbs
Captain Gingerbeard
shibbs's Avatar
Drives: 2012 IOM RS/SS 6MT
LEDs aren't going to be as bright as HIDs. The reflectors are tuned for the HID capsules and LEDs are not going to have the light emitting from a small enough point.
Custom ordered 2012 6MT RS/SS on 11/25/2011. Picked up 01/31/12.
Pedders Coilovers, BMR trailing arms and toe-links, Prothane solid poly subframe bushings, JDP Motorsports rear upper control arm bushings, Texas Speed long-tube headers with 2" primaries, modified fully 3" Magnaflow competition catback. CAI cold-air intake. DBA rotors, Hawk pads.
'Hellcat' sounds like some kinda 15 year old furry with liek "I'm a blue fox with wings and magical kawaii powers" kind of sh*t.
shibbs is offline   Reply With Quote
Old 08-27-2019, 07:07 AM   #3
Lacpac
Lacpac's Avatar
Originally Posted by ChevyMan86 View Post
I wanted to do fanless LEDs instead of HIDs, and even bought a pair of fanless LEDs (Hikari Ultra - https://hikari-led.com/headlight-bul...rsion-kit.html). But my local shop refused to install them, saying they won't work in my lights. They said that LEDs won't replace HIDs, but can replace regular halogens. I am not sure, if that's true, I will talk to the other shop....
I would be interested to see what they say. There are companies that make LED units that look similar to the HID bulb. Headlight Experts is one of the companies. Also companies on aliexpress.com You have to bypass the ballast with a plug and play decoder connected to the light. I've switched over to LED in a `92 Olds, `09 Pontiac, and a `15 Ford. All of them are brighter, whiter, and run cooler at less wattage than the Silverstars I had in them previously. The HID in the `12 Camaro suck. I've tried 4300k, 5000k, 6000k, and all of them are just too dim.
