Old 08-27-2019, 10:13 AM   #1
BigMatt
2010 Camaro 2 SS/RS M6
BigMatt's Avatar
Drives: 2010 Camaro SS/RS
Send a message via AIM to BigMatt
LPE fuel pumps and FPCM tune
Hey guys I have the LPE dual fuel pumps with their fpcm that I installed years ago with ID850s. I started running flex fuel and at higher ethanol content I'm having fuel pressure issues, dropping from 58psi down to 41psi.
Does anyone know if the LPE fpcm is able to be tuned through HP tuners to increase output like the zl1 pumps? Right now everything in the desired fuel pressure is set to 400kpa.
I just ordered a second meth nozzle for my alky control setup to help.
Forged LS3, FED M311 heads, CAI Inc, ARH 1 7/8, Corsa Xtreme, Taylor Wires, MGW Shifter, Street slayer twin carbon clutch, Tick braided clutch line & speed bleeder, ZL1 Diff Swap, BMR Split drop, Sway Bars, Trailing Arms, Toe Rods, Pro bushing kit, Carslyle racing 15in conversion, Whipple, LPE dual fuel pumps, Rx catch can, Id1300x, Alky Control
BigMatt is offline   Reply With Quote
Old 08-28-2019, 11:08 AM   #2
joshnmn
2&THEHIT
joshnmn's Avatar
Drives: 5th Gen Camaro; 5th Gen Ram 3500
from what I have read, the LPE system wasn't compatible with E
joshnmn is offline   Reply With Quote
Old 08-29-2019, 04:11 PM   #3
JANNETTYRACING
JANNETTYRACING's Avatar
You can read out the FPCM with HPtuners they are already set on kill.
CTSV twin pumps run out at 750 RWHP on Gasoline as Ethanol content goes up that number comes down.
Time for a Fore innovations twin pump set up along with ID1300s, the 850 are likely running out too.
Ted.
www.jannettyracing.com
Celebrating 39 years Performance parts, Installation, Fabrication, Dyno tuning, Remote custom tuning, and alignments. 203-753-7223 Waterbury CT. 06705
email tedj@jannettyracing.com
Old 08-29-2019, 05:14 PM   #4
dreksnot
Served USN - Atomic Chimp
dreksnot's Avatar
Drives: 2021 Camaro ZL1 1LE A10 (stock)
Ran mine with E for 3-4 years, no problems. Got about 735whp with it and a KB BAP.
> Past Builds: 2013 Twin-Turbo LSX434 M6 - 1,359rwhp daily
dreksnot is offline   Reply With Quote
Old 08-30-2019, 09:42 AM   #5
BigMatt
BigMatt's Avatar
Ted.
Yea the ID850's are maxed out with ethanol. I guess I'm tearing the car back apart this winter for bigger pumps and injectors.
Old 08-30-2019, 11:36 AM   #6
BigMatt
BigMatt's Avatar
what was your fuel pressure on ethanol at wot with the BAP?
Old 08-30-2019, 03:27 PM   #7
dreksnot
dreksnot's Avatar
At the end of the mile run in 5th gear running 12.5psi boost, fuel pressure hung at 52psi.
Old 09-24-2019, 04:47 PM   #8
xc_SS/RS
I think you can set the pressures to 450 kpa and it should increase (CTS-V regulator I think is 65psi or higher). I had to set normal and high flow to 450 kpa to get higher pressure with my new pump while WOT. But if you're already losing pressure on ethanol you likely need a new pump.
Has it dropped pressure before with ethanol? If no, your current pump is going out. If yes, you need a bigger pump.
As Ted said that pump and fpcm will be set to run a max pressure of 65 psi already. No point in trying to tune the fpcm to give more if it's already losing pressure
2010 2SS/RS
Z/28 intake, NW, FAST 102, speed engineering LT's, some exhaust, ATI -10% pulley, GM flex fuel injectors, DSX flex fuel sensor, MGW shifter, HP Tuners, some suspension work, stickers and a little weight loss. 12.63 @113.53
xc_SS/RS is offline   Reply With Quote
Old 09-24-2019, 04:49 PM   #9
JANNETTYRACING
Should be 71 psi with the CTSV pumps
