Old 08-29-2019, 03:15 PM   #1
Tolstrup
Drives: Camaro 2SS/RS convertible 2011
Question Sound on, sound off, sound on....
Denmark calls for your help. I drive a 2011 2SS/RS Convertible. The audio (Boston) plays for a few seconds, then disappears for a second, plays for a few seconds an so on... If I switch the radio off, the subwoofer in the rearseat makes a continuos deep pounding noise. Only way to make it stop, is to switch the car off completely.
In some cases (not always) the indicator lights blinking sound has a similar error. It blinks twice, then skips a blinking sound or two, then two blinking sounds etc etc....
I've checked the fuses, but they all look ok.
Any suggestions as to what the error may be?
Tolstrup is offline   Reply With Quote
Old 08-29-2019, 03:57 PM   #2
SquawkVFR
Drives: 2010 Camaro
You deny us Greenland then seek help? How dare you!
That sounds like a wiring problem and the first place I’d check is the wiring on the amp in the trunk on the rear drivers side.
SquawkVFR is offline   Reply With Quote
Old 08-30-2019, 02:45 AM   #3
Tolstrup
Thanks - btw, It's Greenland, not Iceland
Danish PM to Trump: Hey, want to hear joke?
Trump: Sure
Danish PM: Greenland
Trump: I dont get it
Danish PM: No, and you never will :-))))))
Old 08-30-2019, 09:52 AM   #4
SquawkVFR
Drives: 2010 Camaro
Trump: Sure
LMAO. Greenland Iceland I doubt he knows the difference.
Keep this updated on the wire checking...
Old 04-19-2020, 12:03 PM   #5
Tolstrup
UPDATE: Got a new (used) amp shipped from the US to Denmark - Installed it and everything seems to be working now. The old one has clear signs of moisture attacking the metal. I believe the problem is the vent in the wheel well, so I put some hard foam between the vent and the amp. Hope it will keep the problem away.
audio, blinkers
