Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > General Camaro Forums > Camaro ZL1 Forum - ZL1 Specific Topics > ZL1 Wheels/Tires
Old 08-31-2019, 10:52 PM   #1
rednecks70
Drives: 2013 AGM ZL1, '70 Chevelle 454
Will 2012 RS Wheels fit a 2013 ZL1?
Title pretty much says it all. The tires are 245/45 and 275/40 on 20" wheels. I read other posts where it says the wheels must be from an SS to fit a ZL1, are the SS and RS wheels different?
rednecks70 is offline   Reply With Quote
Old 09-01-2019, 02:44 AM   #2
HDRDTD
As long as they are the 20" wheels, they should fit just fine. They have to be the 20" size in order to clear the ZL1's Brembo brakes.
Old 09-03-2019, 04:07 PM   #3
Boother
Drives: 14 ZL1
Factory 20" SS wheels (of any year 2010-2015 and design) will fit a ZL1. I have a set of 45 anniversary SS wheels i use in the cold seasons.
Boother is offline   Reply With Quote
Old 09-03-2019, 04:25 PM   #4
vinman
The BBOMG fill-in husband
vinman's Avatar
RS and SS wheels are the same wheel, the v6 version had 18" base wheels, 19" wheels and if you got the RS package you got the 20's that the SS has
UPSTATE C5 MEMBER
vinman is online now   Reply With Quote
Old 09-28-2020, 07:27 PM   #5
THeSilverBeastmero
THeSilverBeastmero's Avatar
Drives: 2012 2LT RS Camero
ZL1 WHEELS
I have an rs stock, I've been wanting to modify my wheels to ZL1. First concern is the wheels size. I will be buying some ZL1 Reps GLossy black, but I've been told that the size I would have to get is 20X9 front and 20x10 rear, how true is this?? I was told that's the only size they will fit on my RS. I currently have 20 inch stock wheels. I wanted to go with standard 20x10
25mm offset front and 20x11 44mm offset rear, is that doable on RS?
I heard of ppl having 20x9 front and 20x11 rear? Does it matter?
Thank you for feedback!!!!
THeSilverBeastmaro
THeSilverBeastmero is offline   Reply With Quote
Old 10-01-2020, 08:09 PM   #6
witenite
witenite's Avatar
Drives: 2010 2SS non RS
ZL1 sizes (20x10, 11) will fit with no problems. I think they are +23 and +43 offsets. May have to zip tie or relocate your rear ebrake cables out of the way or they may rub. That's about it.
witenite is offline   Reply With Quote
