Old 09-04-2019, 03:51 AM   #1
TrickOrTrEatSS
Drives: 2010 SS Camaro L99
Something is Terribly Wrong
I have a 2010 Ss Camaro L99 and it’s very very slow I’m talking 14.7 1/4 mile in 97 Degrees weather and 14.2 when it cooled down but no engine light is on what wrong or what could be wrong cause I thought these cars ran miD 13’s
TrickOrTrEatSS is offline   Reply With Quote
Old 09-04-2019, 07:51 AM   #2
Benman
Benman's Avatar
Drives: 13 IOM 2ss RS manual
Could it be a loose nut between the seat and steering wheel? J/K. Need more information. Are you running with all nannies turn off? getting traction off the line? what's your 60' time? MPH? Are you using premium gas? Has the timing table been reset doing the #5 and #20 fuse pull to make sure the car is running on the premium fuel tables?
Rectangular Dollars will beat Cubic Inches
Benman is offline   Reply With Quote
Old 09-04-2019, 08:00 AM   #3
hrpiii
AKA "Beefcake"
hrpiii's Avatar
Drives: 2023 ZL1 Sharkskin
Maybe high 13's on a cool day, by not mid 13's, not stock in high heat like that.
Do everything Benman suggest, and that should squeeze the most out of the stock 2010 SS.
Old 09-04-2019, 09:42 AM   #4
zlathim
zlathim's Avatar
Drives: 2010 Camaro 2SS/RS M6
What's the DA? I've seen stock SS Camaros run low 14's and high 13's a lot at our local track.
Otherwise, you can try the fuse pull and see if that helps.
GPI SS2; EE E2 catch can; SP 1 7/8" LT Headers w/ hfc; FM AT 3" cat-back; CAI Cold Air Intake; AEM Wideband
Tuned by GPI
McCleod RXT; MGW flat stick; Ram Clutch slave cylinder & hydraulic adjuster
BMR cradle & diff bushings, trailing arms, toe rods & upper control arm bushings
Hotchkis sub-frame brace
Stop Tech Z-23 brakes
4.10 gears, Eaton Truetrac, LPW diff cover
Best 1/4 mile 12.073 @ 115.68 mph 3,300 ft DA
zlathim is offline   Reply With Quote
Old 09-04-2019, 10:07 AM   #5
InFiD3ViL
InFiD3ViL's Avatar
We need more information on the car.
Octane, stock tune, modded or not? The L99 is a great performer once tuned and modded, but in stock form can leave a bit to be desired. I didn't want to admit it at first but it is the nature of the car in stock form unfortunately.
I remember trying to get frisky with a 2015 Mustang GT just after I got my car and while it was bone stock. It was embarrassing how badly that GT spanked me. Wasn't even close. It was that moment that I remember so clearly that the mod bug bit my ass.
You do not need to open this engine up to have fun with it. It responds amazingly to bolt on parts and tune. Just remember that there is always someone out there with a faster car and bigger wallet. Also keep in mind that it is all relative. 20-30 years ago, some guys would have sold their soul to have a factory car running 14 second 1/4s. It is not slow. There are just a ton of fast cars now.
Old 09-04-2019, 10:17 AM   #6
Juiced1
Drives: 2012 2SS CAMARO 45th
Those numbers could be about right depending on a few other factors. If you are bone stock it sounds like its time for some mods. Check out some of our package deals we have going on. It makes it real easy to add some power.
Juiced1 is offline   Reply With Quote
Old 09-04-2019, 11:41 AM   #7
G8One2
Drives: 2014 Camaro 2SS
Pretty sure my old 2016 escape 2.0L turbo did 14 sec in the 1/4. Might have been 15 second, can't remember.
G8One2 is offline   Reply With Quote
Old 09-04-2019, 11:52 AM   #8
Venomcustom
Hard to want.
Venomcustom's Avatar
Drives: 2020 red hot 1SS 1LE
Those times are in line for a hot humid day in Georgia. Especially if you’re new to drag racing. You may hit a high 13 at ATCO. Lol
Venomcustom is offline   Reply With Quote
Old 09-04-2019, 02:02 PM   #9
Moto-Mojo
Fast Cars and Old Guitars
Moto-Mojo's Avatar
Drives: 2015 2SS RS (L99, baby!)
And that my friends is how selling works!
Moto-Mojo is offline   Reply With Quote
Old 09-04-2019, 03:03 PM   #10
Chris49066SS
Chris49066SS's Avatar
Drives: 2010 SS L99
Rest in peace, Gringo. The Camaro5 world is just a little darker without him when threads like these pop up lol...
No but really, OP, listen to the guys, they speak the truth. And Jason at Juiced can feed that mod bug with some good discounts!
Previous PB:11.079 @ 122.99mph.. New setup time: TBD
The 11.079 pass: https://youtu.be/pz27Zq54t_E
Build thread - www.camaro5.com/forums/showthread.php?t=555371
Chris49066SS is offline   Reply With Quote
Old 09-04-2019, 03:20 PM   #11
davidscamaro
davidscamaro's Avatar
Drives: 2010 SS/RS M6 BIG cam
Those times sound right for bone stock L99. 5th gen are heavy cars.
BIG cam ...... 305 45 18 Mickys ...... BMR suspensions
davidscamaro is offline   Reply With Quote
Old 09-04-2019, 05:22 PM   #12
Rock-It Man
376 cubic inches of fun
Rock-It Man's Avatar
Drives: 2023 Camaro ZL1 A10
I have a bone stock 2010 L99 with all season tires.
The worst I have ever done is 14.2 or so, and that was my first time ever at a drag strip.
Since then, I have made something like 40 runs and only three others were over 14.0 seconds. However, most were in the 13.8 range. Under 13.5 only happens on cool and cloudy days or at dusk.
If you can't get better than 14.7, you may need to work on your launch before blaming the car. Do not jab the fast pedal, but instead count one thousand one as you step on it, while gradually releasing the brake with your left foot.
Rock-It Man is offline   Reply With Quote
Old 09-04-2019, 06:14 PM   #13
redcoats1976
yeah,it was a lot more active when gringo and the V8 boys would mix it up.those were the good old days.
Old 09-04-2019, 09:10 PM   #14
InFiD3ViL
InFiD3ViL's Avatar
Having fun and ragging on each other is one thing. He was just outright obnoxious and toxic. That stuff really wasn't good for the site. Which is a shame, as he was a decent person when he wasn't acting that way. He just got carried away and refused to reel it in.
slow
