Old 09-09-2019, 03:36 PM   #1
15RS2NV
Ponies are for girls
15RS2NV's Avatar
Drives: 2015 RS LFX Red Hot A6
RS2NV's '15 RS "Christine"
Stock LFX V6 3.6L 217 ci motor with 25k miles when purchased in Sept '18 (big plastic heat cover removed, permanently)
No leaks anywhere on the car. Spotless top to bottom. Arizona car it's whole life so no rust anywhere, not even on the exhaust.
H&R 1.8/1.7” drop, Overkill 80mm + intake ported by AFS, 1" insulator MACE, Accel Super Coils, THR cai, JET MAF sensor, Hurst shifter handle, GPP strut tower brace, CI ice cube tray hood vents (functional) @SemperFiCamaro
15RS2NV is offline   Reply With Quote
Old 09-09-2019, 03:39 PM   #2
15RS2NV
15RS2NV's Avatar
Replaced stock air filter system with CAI
As most people do, first thing is allowing the car to breathe better, out with the restrictive stock air filter system, and in with a basic cold air intake off Amazon. I'll get a bigger and better one later, so i didn't want to spend a lot on this at this point. Also, heat insulation removed from "valve covers" which are actually cam covers.
Old 09-09-2019, 03:56 PM   #3
ChibiBlackSheep
ChibiBlackSheep's Avatar
Drives: 2012 2SS/RS, 1968 SS
The stock air intake actually flows really well on the LFX.
The first thing you should do is some type of catch-can to prevent that nasty build-up that direct injection engines suffer from
Also a nice tune. Really wakes the v6 up. Especially when paired with new downpipes + high-flow cats.
I'd personally save the money from an intake.
LS3 Crate Engine Swap | CSP Custom Cam 232/240 .615/.615 113 +3 | Stainless Power LT Headers | Z28 Intake | Borla S-Type Exhaust | FTI Triple-Disc Billet 3200 Stall
2012 Camaro 2SS/RS | 1968 Camaro SS | 2020 Cadillac CT5 Premium Luxury | 2021 Spark LS
ChibiBlackSheep is offline   Reply With Quote
Old 09-09-2019, 04:23 PM   #4
15RS2NV
15RS2NV's Avatar
It has the NPP exhaust, so not going to change that anytime soon. I'm looking to upgrade to 80mm throttle body and having the intake manifold ported to match. After that looking to get the Overkill procharger setup which comes with a tune.
Old 09-09-2019, 04:30 PM   #5
ChibiBlackSheep
Then I would definitely not even bother with an intake. You would just uninstall that when you boost it.
Old 09-09-2019, 04:35 PM   #6
15RS2NV
15RS2NV's Avatar
Lowered with H&R sport springs
Lowered Christine's height with H&R Sport Springs 1.8" front and 1.7" in rear. Eibach and others didn't go low enough for what i wanted her to look like. Now that's they've settled, she looks like she should. Top of the wheel wells come to the top of the tires.
Old 09-09-2019, 04:38 PM   #7
15RS2NV
15RS2NV's Avatar
I figure after I get the TB and the ported intake manifold, i'll get a larger tube for the CAI. There will be some time before i get the procharger setup.
Old 11-27-2019, 06:06 PM   #8
15RS2NV
15RS2NV's Avatar
80mm TB, ported intake manifold and spacer, Hurst shifter handle
Finally added some performance goodies under the hood. Overkill's 80mm throttle body was added to the Aor Flow Solutions' ported intake manifold that sits atop the MACE Engineering 25mm (1") intake manifold insulator (spacer). Add in some Accel ignition Super Coils to help with spark and the fun begins.
Results: I dyno'd while still in learning mode but wheel hp jumped from 289 last year to 324. Throttle response though is dramatically improved. It takes very little pedal to speed up or even from a stop. My NPP exhaust opens at 3k rpm but now i rarely get to 3k. I'm looking forward to the next track day so i can see what my ET is at now.
As you can see, i'm still working on polishing the cast aluminum DOHC covers and water pump. It's definitely a work in progress.
Hurst shifter handle isn't for performance, but thought it would be really cool to have inside.
Old 02-19-2020, 09:43 PM   #9
15RS2NV
15RS2NV's Avatar
Added hood vents from '68-'69 Camaro
Deleted the 'CAMARO' letters from the fenders, then drilled and installed 'rally-sport' emblem from '68 RS. (yes, i know it's crooked)
Also from '68-'69 is the big block 'ice cube tray' hood vents. However, unlike the earlier Camaros, these are actually functional. Living in the desert, i needed some kind of way for the heat to escape from the engine compartment. These definitely fit my retro look. (You can see the strut tower brace through the screen!)
Old 03-06-2020, 11:57 PM   #10
15RS2NV
15RS2NV's Avatar
next upgrade will be...
Next, I'll be getting a tune from Overkill. Then i'll take it to the drag strip and see how it does with all the upgrades.
Old 09-07-2021, 03:22 PM   #11
15RS2NV
15RS2NV's Avatar
Update on where the Camaro is so far: I have the Accel Super Coil ignition coils, MACE Engineering 1-inch (25mm) intake manifold spacer, Overkill 80mm throttle body, ported throttle body and intake manifold by Bret Barber @ Air Flow Solutions, JET Performance MAF Sensor, and 3.5" cold air intake, GMPP strut tower bracerear
Name:  current LFX pic.jpg
H&R Super Sport lowering springs 1.8" front/1.7" rear, APS Phantom black powder coated stainless steel grille, Classic Industries 'ice cube' hood vents, Name:  Latest RS pic.jpg
