![]() Drives: 13' Camaro LT Join Date: Jun 2019
Trunk Stuck Shut
Trunk is jamned shut on my 2013 vert. Went to try the keyhole behind the seat and it doesnt do anything? Keyfob and door button I hear a click by the steering wheel. No noise of trunk unlocking. Wires were caught in the gasket so I assume one broke but thought the key hole was a manual release??
![]() Drives: 2014 Camaro 2SS/RS 1le Join Date: Jan 2017
Mine got jammed once I got it open by grabbing the interior emergency handle. Dropped the back seat and reached in the trunk.
Yea cant drop the seat in the vert. Easy to remove seats?
Oops
Drives: 2013 Sparkly Red One Join Date: Dec 2018
#6 |
Geoff
Drives: 2022 SS 1LE Join Date: May 2013
Spray some PB Blaster or equivalent into the lock
Wait a bit Try turning it further. The key has to turn a long way. It seems unlikely that both the wire and cable failed at the same time not impossible just unlikely. Otherwise you’ve got to start taking the car apart
#7 |
Yea just dont want to break the key trying to turn it, its already a little loose.
#8 |
Started#gottalovethatblue
Where is the trunk keyhole? I've had my bow tie off before and looked all over the car at different things, but I've never seen a trunk keyhole.
#9 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2013 Triple Black ZL1 Vert M6 ECF Join Date: Mar 2011
Read about it in your manual. This is for the convertibles only, and is there because the rear seats do not fold down like in the coupes. From the manual.... Emergency Trunk Release Lock (Convertible Only) If the trunk lid cannot be opened using the RKE transmitter or the trunk release button: 1. Locate the manual release beside the rear seatback cushion on the driver side. 2. Pull the cushion to the side, then fully insert the key into the lock cylinder. 3. Firmly turn the key clockwise to unlatch the trunk lid. 4. Remove the key. |
#10 |
Have someone try to lift the trunk while you hit the button. Sometimes they just need some extra help to open if they are a little jammed.
#11 | |
#12 |
Wondering if this wiring harness is available? Lol
#13 |
![]() Drives: 2013 Camaro SS Vert Join Date: Apr 2019
Battery died on my vert just last night. Car was in the garage and I had no way to back it out (L99) or get a car close enough to jump it using the post under the hood. I crawled in the back seat and you can reach the manual release if you have long arms. You just have to flip the cover (not sure the real name) up a little to reach under it. Popped the truck and put the cables on the battery direct. Didn't know about this emergency release. I will have to go check it out.
#14 |
Wow. Looks like you have a critter problem there. Hopefully they didn't get into anything else.
