Old 09-12-2019, 05:54 PM   #1
lionssfan
lionssfan's Avatar
Drives: 2010 2ss camaro
Any zl1 owners have the MGW shifter?
just bought zl1 manual trans and thinking of putting a MGW shifter in. I know the shifters had improved since the 2010 Camaro I had with manual trans. I had a hurst shifter at first in my 2010 but later went with the MGW and loved it. What has been your guys experience changing it in the zl1 to the MGW shifter. thanks
2012 zl1 stock 7000 miles
2010
TVS2300, BTR cam PD stage 3, ID1050 injectors, CHE bronze trunnions, 7.400" pushrods,.660" lift platinum springs, Titanium ret, Zl1 fuel pump, Kooks LT headers, High flow cats, Roto Fab CAI, Corsa exh., Mellings oil pump, HD chain, ls2 damper, all synthetic, BMR control arms, zl1 toe link, BMR cradle mounts, W/bottle relocation, air scoop deflector, Hennessy wheels, two piece rotor, morimoto fogs, DRL harness, coilovers, Heads up install, mgw shifter, slps splitter, slp spoiler, zl1 side skirts, painted strips, debadged, tinted, 2018 emblems.
Edit Signature
lionssfan is offline   Reply With Quote
Old 09-12-2019, 06:43 PM   #2
owhite3003
Z-BEAST
owhite3003's Avatar
Drives: 2013 JDP ZL-850 Track Spec ZL1,
Yep and love it. Has a better spring rate and I like how the flat stick is angled back a bit.
owhite3003 is offline   Reply With Quote
Old 09-12-2019, 06:47 PM   #3
lionssfan
lionssfan's Avatar
ok cool , add it to my bucket list . thanks man
2010
Edit Signature
Old 09-13-2019, 02:40 AM   #4
PJMZL1
PJMZL1's Avatar
Drives: 2015 ZL1
Yes get the MGW flat stick. Its awesome!
2015 ZL1 M6
PJMZL1 is offline   Reply With Quote
Old 09-13-2019, 05:44 AM   #5
lionssfan
lionssfan's Avatar
What's flat stick mean. Looks like they two different styles thanks
2010
Edit Signature
Old 09-13-2019, 09:33 AM   #6
GONMAD510
Drives: 2013 ZL1 M6
I have the MGW flat stick. I love it.
Fast 850cc Injectors, ATI Balancer, 8.66 Lower Pulley, 2.55 Upper Pulley, Lingenfelter CAI, Kooks LT with cat delete pipes, Noweeds Exhaust Cutouts (extremely loud under full throttle), BTR Stage 3 Cam, BTR Platinum 660 Valve Spring Kit, TR7ix Iridium Spark Plugs, Lingenfelter Solid Isolator, 160 Degree Thermostat, Larger SC Coolant Reservoir with Hose Relocation Kit, BMR 1.25" Lowering Springs, MGW Short Throw Shifter, Racing Brake 2 piece rotors front and rear, Starkweather Performance Custom Dyno Tune on 91 Octane.
691.38 RWHP
630.35 RWTQ
GONMAD510 is offline   Reply With Quote
Old 09-13-2019, 12:10 PM   #7
Harley01
Drives: 2015 Camaro ZL1 (red hot)
+1
My Mods:
Roto-Fab Intake, Elite Catch Can, ATI Super Damper & 28% OD Pulley, LF Idler pulley bracket, ID850 Injectors, 2" Kooks LT coated headers w/orp, BTR Stage 3 cam, Mild to Wild exhaust controller, TR71X Spark Plugs w/socks, JMS Fuel Pump Booster, LS3 Throttle Body, Alky Meth injection, Ron Davis HX, Roto Fab Reservoir, BMR 1.4" Lowering Springs, Side Vents, Rock guards, Custom painted splitter, rockers and rear fascia, MGW Short Throw Shifter, ZL1 DRL lighting harness, Aeroforce Scan gauges, Car Lock security system, Tuned by JDP Motor Sports, Dyno Tuned (702 RWHP).
Harley01 is offline   Reply With Quote
Old 09-13-2019, 01:06 PM   #8
owhite3003
Z-BEAST
owhite3003's Avatar
https://www.mgwshifters.com/shifters/camaros/81
Old 09-16-2019, 12:35 PM   #9
2NASSTY
2NASSTY's Avatar
Drives: 2014 M6 ZL1
Loved the MGW shifter, but went back to Stock for faster shifts and NLS on track/street.
MGW Very notchy on WOT 7K rpm shifts compared to factory shifter. Loved the MGW Flat stick, but missed a lot shifts at the track with it. Maybe it was the Driver
15' Ashen Gray Metallic Z/28
14' Crystal Red Tintcoat ZL1 6M, 9.62 at 150.75 MPH
12' Opulent Blue Metallic CTS-V Sedan, 10.690 at 129.60 MPH - SOLD
06' LeMans Blue Metallic Z06, 11.726 at 127.80 MPH Motor - SOLD.
96' Impala SS LTx, 11.397 at 118.10 MPH Motor, 1st stage 10.526 at 127.46 MPH
2NASSTY is offline   Reply With Quote
