![]() Drives: 2015 Summit White 2SS 1LE Join Date: Dec 2018
Stock pads for 2015 1LE
Hey all,
Tried looking around a little bit, maybe my searching is garbage, but I couldn't find specifically what Brembo pads to get that are OEM replacement. Are the OEM GM pads from Brembo? Does anyone happen to know exactly what pads? Two results came up on the Brembo site, but it only says 2015 SS and doesn't specify 1LE or not. Also open to OEM replacements and advice. Thanks guys! Forgive my ignorance, still learning about my 1LE. |
Tri-County Camaro SWFL
Federra or something like that are OEM
![]() ![]() Drives: 2015 BVM Camaro 1LE (2SS/RS) Join Date: Mar 2012
1LE brakes are same as SS, calipers just painted red.
![]() ![]() ![]() ![]() ![]() ![]() Drives: 2013 Camaro 1LE Join Date: Jul 2012
Search for ACDelco P/N 1711112.
Rock Auto has them on their site for $118.99. https://www.rockauto.com/en/moreinfo...308746&jsn=974 You might also want to consider getting a new pin kit for the pads. AC Delco 18K1971X https://www.rockauto.com/en/moreinfo...308746&jsn=972
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2022 1SS 1LE A10 BCD WCT+PDR Join Date: Mar 2008
They are manufactured by Ferodo for Brembo/GM and they are the HP1000 pad material. The backing plate will say HP1000
2022 1SS 1LE A10 BCD WCT+PDR2014 1SS 1LE NPP RECARO SIM-SOLD1995 Z28 M6 GSC PGM-SOLD1975 NOVA COUPE 300HP 350 TH350 FLASH RED-SOLD
"KEEP THE FAITH"-Fbodfather |
#6 |
![]() Drives: 2015 BVM 1SS/1LE Join Date: Aug 2010
Hawks brake pads will also fit and are a nice replacement pad. That's what I run on mine. They don't put off anywhere near as much brake dust as the stock ones do.
