Old 09-18-2019, 03:38 PM   #1
imponte
imponte's Avatar
Drives: '10 Camaro SS
Hotchkiss Lowering Springs Rear Height Difference
Hi guys. I just install hotchkiss lowering springs to my 2010 camaro ss. But i have an issue. The front height is equal but rear left is lower almost 1 centimeter against the right side. What can i do?
imponte is offline   Reply With Quote
Old 09-18-2019, 07:51 PM   #2
KillboyPowerhead
Drives: 2015 Z/22
Have you had the bushings timed/clocked/reset/whatever you want to call it? If the suspension is hanging limp and you tighten up all the nuts and bolts then the bushings will all be under extra stress/torqued when the car is on the ground.
You can either mention this to your alignment tech and they can (hopefully) reset the bushings, or you can kind of do it yourself by jacking up the car, loosen all the nuts and bolts of all rear suspension arms, jack up the hub to where it sits when the car is on the ground, and re-tighten all the bolts (this isn't necessarily the best way to do it but it'll get you close).
KillboyPowerhead is offline   Reply With Quote
Old 09-19-2019, 09:19 AM   #3
imponte
imponte's Avatar
thanks to reply. after 1 day and 60-70 mile now height difference is minimal. But car pulls to the left, especially low speed and braking. i do alignment too. But nothing changed. The wheel is straight car is going straight but i feel the force to the left. i let off the driving wheel car is going to the left especially low speed and braking.
Old 09-27-2019, 03:30 PM   #4
JDP Motorsports
JDP Motorsports's Avatar
Drives: 2011 Camaro SS/ 2016 Camaro SS
imponte,
It sounds like the control arm bushings might be the cause of your uneven ride height. As mentioned above, it would be a good idea to loosen the lower control arm bolts and re-tighten while the vehicle is sitting on the ground. After doing that, I would definitely have the alignment re-checked. If you are experiencing a pull, your alignment still needs some work.
Kind Regards,
Stephen
JDP Motorsports is offline   Reply With Quote
Old 09-27-2019, 04:51 PM   #5
imponte
imponte's Avatar
Originally Posted by JDP Motorsports View Post
imponte,
Kind Regards,
Stephen
Thank you.
