![]() Drives: 2010 Cammed Black Camaro SS Join Date: Nov 2016
WTB VENTED HOOD
I’ve been battling with under hood temperature issues with the T4 Huron Speed kit. She’s been burning wires for fun, loaded with Dei and a turbo blanket. Unfortunately ceramic coating is not an option for now I’ve been led to believe a vented hood is my best bet for getting that heat out. If you guys have any proper vents, vented hoods for sale or any advise I’d love to hear it and see what kind of options there are for me.
-Rob Last edited by TheGuy203; 09-18-2019 at 09:55 PM. Reason: Misspell |
![]() Drives: 2010 CAMARO 2SS/RS Join Date: Dec 2016
I built my own custom twin kit and had heat issues at first. I have everything wrapped and blankets also. I ended up putting 2 layers of heat tape on the wires between the boots and heat sleeves over the wires. I also installed a 2014 heat extractor in my stock 2010 camaro. I haven’t had any issues since.
#3 | |
-Rob |
![]() Drives: 2010 Cyber Gray LS3 SS/RS Join Date: Jul 2017
I’m not boosted or having any heat issues but I just put on a Harwood 5” cowl that actually functions.
2010 Cyber Gray LS3-BTR stage 4-480/428 RXT and 3.91’s
![]() ![]() ![]() Drives: 12 2SS/RS L99,11 2SS/RS LS3totaled Join Date: Jun 2019
a few guy here posted pics of the heat extractor install.it will not dump on the maf.
https://www.camaro5.com/forums/showthread.php?t=285601 https://www.rpidesigns.com/shop/item...saApA8EALw_wcB |
#6 |
![]() Drives: 2015 camaro 2ss Join Date: Nov 2017
I have my factory 15 ss hood I would probably sell.
#7 | |
check this out
#8 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 Turbo LS3 Join Date: Dec 2009
Hood vent is a good idea, but for the wires, try Accel ceramic boots with heat shielding over the top. I used stainless steel tie wraps to gather the shielding material just above the ceramic boot.
2011 Vert - 416/w 230/236 .612/.602 115lsa, 1LE suspension w/32mm rear bar. Z28 diff. Gen6 ZL1 brakes. |
#9 |
![]() Drives: Camaro SS Join Date: Jul 2019
Rich2010 how's the visibility with the 5 inch Cowl Hood, do you think I can daily with that hood
#10 |
Wouldn’t be too bad to daily as long as you’re aware of your right front and careful. I drive my car both days on the weekend everywhere with no issues.
