Old 09-19-2019, 05:17 AM   #1
rangerdave1
rangerdave1's Avatar
Drives: 2010 Camaro 2SS/RS LS3
Synchro replacement, big job?
I have a 2010 Manual, curious how big of a job it is to have the synchros replaced with the carbon ones. Mine isn’t to bad but It’s something that bothers me so was wondering how big of a job it is to have done.. I would likely pull the trans myself and drop off at the shop. Parts seem reasonable. Wondering what kind of Labour is Involved .
Anyone have this done?
rangerdave1 is offline   Reply With Quote
Old 09-19-2019, 05:47 AM   #2
Clarkstar
Clarkstar's Avatar
Drives: 2013 1SS 1LE
I sent mine to Tick Performance. It was $1699 with "free" shipping both ways.
2013 1le- Katech 416 short block, TSP custom grind cam, LOD intake, cnc heads by F.ED., Nick William's 102mm T.B., CORN fed, Pedders coilovers. Performance street alingnment by Justin at Lake Country Alignment and dyno tune by Late Model Throttle.
603 h.p. 495 ft lbs tq.
Clarkstar is offline   Reply With Quote
Old 09-19-2019, 06:47 AM   #3
Black_SS10
SomeguyK
Black_SS10's Avatar
Drives: 2010 Black 2SS/RS
The transmission has to come completely apart. I paid a shop 600bucks, I purchased, and dropped off all the parts. It is the same rebuild as Tick but for half the price.
More to come.
Black_SS10 is offline   Reply With Quote
Old 09-19-2019, 07:51 AM   #4
rangerdave1
Yeah Tick is not an option for me
Since I live in Canada
Old 09-19-2019, 11:36 AM   #5
caper
Drives: 2010 IOM 2ss/RS
SO howd you manage that? you pulled the trans yourself? or the shop pulled it, split it, assembled it and reinstalled it? what parts did you use to get the same build? I ask because I am looking at the tick build right now.
Turbonetics running 8lbs boost at 700rwhp tuned by Hi Rev, installed by K&M w/cat-muffler delete, ACS splitter, Fesler GFX, MPD1 spoiler, Custom painted Rally stripes, Cordon CR1 wheels 275/315s, Hotchkiss comp sways and end links, Barton shifter
caper is offline   Reply With Quote
Old 09-19-2019, 12:53 PM   #6
Black_SS10
SomeguyK
Black_SS10's Avatar
Yes, I pulled the trans and dropped it off, then picked it up and installed. I bought most the parts from Tick; carbon fiber blockers rings, bronze shifter cup, and bronze fork pads. I got the rear bearing support from Rockland Gear I got new GM seals and even had to buy a new shifter fork rod because one got bent. I saved some $500+ bucks doing it my way compared to their lvl 1 rebuild. I didnt need the upgraded Gforce shaft, no one really needs it unless you have an early 2010 build. Even then I would just replace it with a GM one.
More to come.
Old 09-19-2019, 01:08 PM   #7
caper
I do have an early 2010 build (got it in dec 09). and was wondering if I would need that part. me pulling and installing isn't an option. 500 isn't a small amount though...so the parts cost you about 600? and the rebuild another 600?
Old 09-19-2019, 02:34 PM   #8
Black_SS10
SomeguyK
Black_SS10's Avatar
Mine was built in sept 09 and didnt have the weak shaft, it was early vin's. The parts cost me thereabout that much, I think it was around $750. Yes, the rebuild cost me $600. I dont know if you would save much by having a shop R&R and rebuild it.
More to come.
Old 09-22-2019, 04:20 PM   #9
dlc
Drives: red 2011 camaro ls
Thumbs up IdealG master
Hello, just wanted to know if you would sell your IdealG master cyl. Glad you got your camaro performing the way you like.
dlc is offline   Reply With Quote
