Old 09-19-2019, 10:32 AM   #1
chevyss69
Drives: 2011 2ss/rs
One piece driveshaft
Looking for recommendations on one piece Aluminium driveshaft. Dss or gforce?
chevyss69 is offline   Reply With Quote
Old 09-19-2019, 01:48 PM   #2
SquawkVFR
Drives: 2010 Camaro
DSS. I can only base that on the fact it seems to be Vengeance racing’s drive shaft of choice and often times the wait to get one can be up to six weeks.
SquawkVFR is offline   Reply With Quote
Old 09-19-2019, 10:58 PM   #3
chevyss69
Drives: 2011 2ss/rs
Thanks for the info
Old 09-20-2019, 01:50 AM   #4
olblue75
olblue75's Avatar
Drives: 2010 2SS/RS
I've had a DSS shaft for 3-4 years bought it used from the forum and no complaints.
I've replaced the hardware due the cap bolt was kinda rounded out.
Orange Krush II
Old 10-06-2019, 11:48 PM   #5
Js2fst
2010 transformer
Js2fst's Avatar
Drives: 2010 ss camaro
This is a1400 hp dss. I switched to g force. Bigger and nicer welds . This was shifting into 3rd gear with 700 rwhp at time.
2010 transformer, vertical doors, 315nt05 rears, pedders supercar coilovers, hotchkis sway bars, links, adjustable, toe bars, bmr poly cradle bushings, 1le control arms, bmr tunnel brace, bmr subframe connectors. Cam 227/239-623-620@114 Mast medium bore heads, sw 1 7/8 headers, cat delete, x pipe, 3" dynomax true duals, fuel rails, fast 102 intake and NW 102 throttle body, catch can, rotofab cai, shifter, raptor custom shift light. Dss drive shaft, 3.91 gears. 492 rwhp
Js2fst is offline   Reply With Quote
