Old 09-21-2019, 12:19 PM   #1
Dirtmod66
Dirtmod66's Avatar
Drives: 2010 Camaro SS
Differential Fluids.
Sorry if this has been asked before, but cant search from my phone. Getting new gears and a Tru-Track installed. I've always ran Red Line in my race cars; would i use the non-synthetic gear oil and has anyone used Red Line in their rears?
Dirtmod66 is offline   Reply With Quote
Old 09-21-2019, 02:49 PM   #2
lemontwist
lemontwist's Avatar
Drives: 12 2SS/RS L99,11 2SS/RS LS3totaled
i would go with some type of synthetic without friction modifier.
lemontwist is offline   Reply With Quote
Old 09-21-2019, 05:06 PM   #3
Black_SS10
SomeguyK
Black_SS10's Avatar
Drives: 2010 Black 2SS/RS
The tru-trac prefers anything without friction modifier. I use a conventional 80/140weight. I called them and was told the weight isn't that important. But that they recomend a conventional fluid without friction modifier. Most synthetics have a modifier mixed in already. Just check the fluid any make sure no friction modifiers are added.
More to come.
Black_SS10 is offline   Reply With Quote
Old 09-22-2019, 09:10 AM   #4
olblue75
olblue75's Avatar
Drives: 2010 2SS/RS
I'm running the correct weight of Royal Purple in my Z28 diff and have been driving it for almost a year with a track day at NCM thrown in with no issues.
Orange Krush II
Old 09-22-2019, 11:21 PM   #5
GRNFLSH
GRNFLSH's Avatar
Drives: 2015 Camaro 2SS Green Flash Edition
I’m using AC Delco synthetic without friction modifier.
Kooks stepped headers & Solo XL Cat-back
ADM CAI w/race scoop & Rotofab w/w relo
GPI VVT SS1 cam and CNC ported heads milled .30
BTR .660 springs, Straub solid bushing trunions
GPI rod-mod intake with I-M heat sheild
Circle D 258mm Pro single disc 3700 rpm stall converter
169F thermostat & manual fan switch
Tuned by Ryno at GPI - 455 RWHP / 416 lb-ft
GRNFLSH is offline   Reply With Quote
Old 10-03-2019, 01:23 PM   #6
Dirtmod66
Dirtmod66's Avatar
Thumbs up Gear Oil
Went with the Red Line 80-90 synthetic gear oil with out the additive, rear is good to go, no noise what so ever. The builder did an excellent job and i even got to watch and he explained what he was doing with each of the tools. never to old to learn something.
