Old 09-23-2019, 01:25 AM   #1
jrlopez522
Drives: 2015 Camaro 2ss
Navigation stuck in Michigan
Hi, I recently purchased this car used a 2015 2ss and ever since I’ve got it I tried using navigation and it pinpoints me in Michigan?? I’ve tried pin pointing my actual location before but nothing has worked have you guys heard about this or know how I can fix it? I went to the dealer and they wanted $130 just to diagnose it so I was hoping there’s an easy fix I can do myself then having to pay the dealer to do it. Thanks!!
jrlopez522 is offline   Reply With Quote
Old 09-23-2019, 05:56 AM   #2
G8One2
Drives: 2014 Camaro 2SS
Idk, I would probably try to restore all to factory defaults.
G8One2 is offline   Reply With Quote
Old 09-23-2019, 06:28 AM   #3
Sir Nuke
Master of All Things
Sir Nuke's Avatar
Drives: '26 Corvette Stingray
in the event you didn't know....there is a place in the infotainment system that has a selection that says "RESTORE TO FACTORY DEFAILTS" and try that.....the once PITA that comes with that is that you will have to set up everything you changed....but there ya go.
Old 09-23-2019, 08:11 AM   #4
Lil35caM
Lil35caM's Avatar
Drives: 2015 Chevrolet Camaro
Try to contact the navigator provider. Did you reset all the settings by the way?
Lil35caM is offline   Reply With Quote
Old 09-23-2019, 10:18 AM   #5
SlingShot
SlingShot's Avatar
Drives: 2012 ZL1 - #670
Pull the Mylink fuse and let it sit for a few minutes, then try again.
Old 09-23-2019, 10:19 AM   #6
Russell James
Russell James's Avatar
I think they gave you an accurate answer... will need to diagnose why it's not receiving the GPS location. Could be the shark fin antenna, cable, wire, module.... Anyone is guessing until they bust into the diagnosis. When it lost it's GPS reception probably defaulted back to engineering location. I doubt resetting factory settings will do it, it's not receiving GPS for some reason. Could try a battery disconnect as a wild guess. Sometimes modules get stuck in bizarre logic lock and a reboot clears out. If a battery disconnect doesn't get it back receiving GPS, just going to need to follow the service manual diagnosis for no GPS.
