Old 09-24-2019, 09:14 AM   #1
tarik1985
tarik1985's Avatar
Drives: 2010 Camaro SS/RS
Smile Help selecting the correct tires size.
Hi everybody.
I'm looking to buy new wheels but they only have them in 20"x9" front and 20"x 10.5" rear (https://www.ebay.com/itm/4rims-set-2...72.m2749.l2649) My current wheels and tires are 245/45/20 front and 275/40/20 rear.
I was told the wheels are a bit wider for my current tires so I'm trying to figure out the correct tires size I'll need to make them fit better. I'm assuming I'll have to go wider but have no idea when tires are concerned. Any help would be greatly appreciate ��
2010 Camaro SS/RS L99.
tarik1985 is offline   Reply With Quote
Old 09-24-2019, 10:36 AM   #2
charles71
charles71's Avatar
Drives: 2011 Camaro SS
275/40/20 up front and 315/35/20 in the rear. These are both 28 28" tall tires
Livernois Stage II Heads & Cam, LS7 Lifters, Ported Intake & Throttle Body, Rotofab CAI, BBK High Flow Fuel Rail @ Guage, Eaton Tru Trac Posi with 3.91 gears, 1000 HP Axels, Kooks Long tubes & full Corsa Exhaust, GM Hurst Short Throw Shifter, Mcleod RXT Twin Disc, Vitesse Throttle Controller, 1.5" Lowering Springs, Strut Tower Brace, SLP 25% Underdrive Pulley, Apex reservoir relocation kit and air scoop.
charles71 is offline   Reply With Quote
Old 09-24-2019, 11:23 AM   #3
tarik1985
tarik1985's Avatar
Thank you for the response.
I was thinking the same thing for the front 275/40/20. And 305/35/20 for the rear.
Old 09-24-2019, 12:40 PM   #4
KillboyPowerhead
Drives: 2015 Z/22
305/35/20 is also doable in the rear, with only ~0.25" difference in diameter compared to a 315, less than how much a tire wears over its life (which is roughly 0.5").
KillboyPowerhead is offline   Reply With Quote
Old 09-24-2019, 01:40 PM   #5
tarik1985
tarik1985's Avatar
Thx for the input..
Is there a benifit of running the 315 over the 305?
Old 09-24-2019, 05:16 PM   #6
102SS
waiting at the tree
102SS's Avatar
Drives: SIM 2010 2SS/RS A6
Thx for the input..
Your more vulnerable to stone chips on the quarter/valance.
2010 2SS/RS A6 Just a few bolt-ons and appearance doo dads
102SS is offline   Reply With Quote
Old 09-24-2019, 05:20 PM   #7
tarik1985
tarik1985's Avatar
Never thought of that 🤔... So overall the 315 is a better choice for the 10.5 inch wheels. I just hope I won't have any rubbing problems.
Thank you guys.
Old 09-24-2019, 05:22 PM   #8
102SS
waiting at the tree
102SS's Avatar
Thank you guys.
Only if you don't mind the stone chips.
I went with 305's on my 20x11's based on the previous owners recommendation.
Old 09-24-2019, 05:31 PM   #9
tarik1985
tarik1985's Avatar
Damn 11" is pretty wide I bet it looks great. Did u experience any tire rubbing problems?
Old 09-25-2019, 08:15 PM   #10
102SS
waiting at the tree
102SS's Avatar
None they are factory 5 spoke ZL1 wheels 20x10 and 20x11.
I could have went 295 front and 315 rear but I stuck to the stock size 285 and 305.
Old 09-25-2019, 08:23 PM   #11
tarik1985
tarik1985's Avatar
What is the offset on them if you don't mind me asking.
I went 275/40 front and 305/35 rear. My wheels have a 25 and 45 offset. I'm worried the wheels might stick out too much past the fender.
Old 09-25-2019, 08:53 PM   #12
KillboyPowerhead
Drives: 2015 Z/22
The factory ZL1 wheel specs are +23mm front and +43mm rear, so your wheels will be 2mm further inward. Nothing to worry about unless you're lowered a fair bit.
Old 09-25-2019, 08:59 PM   #13
tarik1985
tarik1985's Avatar
Thx for the response .. Car isn't lowered at all. Already ordered the wheels and tires.. So I'll be finding out soon 😊
