Old 09-28-2019, 06:49 AM   #1
Trike rider
Drives: 2014 ss 1Le
Almost ready
I know the 1LE is not ideal for a drag racing car but i am going to give it a shot. Car has to go to tuner still but very close to some track time. I think i am taking a good first swing at it. I went with texas speed heads, biggest cam with stock bottom end, rocker upgrade, push rods, fast 102 intake, cold air intake, e85 tune, fast 102 nitrous outlet kit, stand alone fuel system, long tube headers. Control arms and everything else in rear for some kind off traction. Is there anything else i might have overlooked. This is my first camaro so not sure the week links. and yes the clutch was upgraded as well as the engine oil pump.
Trike rider is offline   Reply With Quote
Old 09-28-2019, 07:12 AM   #2
Rons1le
Rons1le's Avatar
Drives: 2015 Camaro 2SS RS 1LE AGM
Subframe connecters? How big of shot of nitrous?
Sent from my SM-G960U using Tapatalk
2015 2SS RS 1LE NPP/w Kooks headers, Procharged, ID1050X injectors, Katech belt tensioner, Mighty Mouse Catch Can, BMR subframe connectors, Matco driveshaft loop, AEM Wideband/Boost/Fuel gauges , Z/28 Splitter and Spoiler/w Wicker bill, Power Stop rotors and brake pads, MRR Z/28 Rep Wheels 20" w/p zeros 285 fronts and 305 rears, ZL1 addons Rock guards and Tow hook, Rear window louvers, Flags on the quarter windows and the moonroof, Billet aluminum door handles.
Rons1le is offline   Reply With Quote
Old 09-28-2019, 07:18 AM   #3
Trike rider
Drives: 2014 ss 1Le
I am going to run between a 150 and 200 shot off nitrous. So like the mustang i need to look into some type off sub frame connectors
Old 09-28-2019, 07:38 AM   #4
Rons1le
Rons1le's Avatar
BMR make set I have them on mine helps with higher rwhp twist.
