![]() ![]() ![]() ![]() Drives: 2013 1SS 1LE Join Date: Jun 2016
LLSR cam anyone?
Thinking of taking the plunge this winter. Tell me your set up and experiences....
Thanks
2013 1le- Katech 416 short block, TSP custom grind cam, LOD intake, cnc heads by F.ED., Nick William's 102mm T.B., CORN fed, Pedders coilovers. Performance street alingnment by Justin at Lake Country Alignment and dyno tune by Late Model Throttle.
603 h.p. 495 ft lbs tq. |
![]() ![]() ![]() ![]() Drives: 2015 1LE Join Date: Oct 2015
No but I wish I would have, I'm sure you know you need adjustable rockers.
2015 1LE, TSP 225/236 113+3, VMAX Throttle Body, CAI with race scoop, GPI Ported Intake, Land Speed Stage 2 Heads, 1-7/8 headers, NPP exhaust, 25% Fluidampr, LT1-S Monster Clutch, 485 RWHP & 444 TQ
Some have used the stock ones and shimmed them. Looking for what others have done... jessel?
#4 | |
![]() Drives: 2015 Camaro 1LE Join Date: Sep 2015
Current setup is 416ci with LS7 Heads, 12.7 compression, 102 mm TB, MSD intake (waiting for LOD to get the LS7 version ready) E85. Cam is LLSR 26x/27x about 720 lift, Harland Sharp rockers. |
If it were me, I would just get the Jesel ones. Then you can fine tune the lash without any hassle. Most people probably don't run them because of the extra cost but from what I have read, they always make more power and the noise is actually less than a hydraulic lifter.
#6 | |
#7 |
#8 |
250/262 duration @ .050’’
112+4 .705’’/.688’’ lift with 1.7 rocker This is what they speced for me...
#9 |
Just because you get a LLSR does not mean you have to put in a massive cam. That cam will be tough to tune well for a street car. Arch City also has a massive cam that is around 260@.050.
250/262 duration @ .050’’ 112+4 .705’’/.688’’ lift with 1.7 rocker This will make good power but will be tough to drive I would think.
#10 | |
#11 |
Ya, I keep forgetting you have a 416 plus you lose a little on duration from the lash. Should be a great cam for that motor. Its close to this and look at how well it worked on this motor. https://www.enginelabs.com/engine-te...ild-with-ffre/
#12 | |
#13 |
Clark,
Go over to LS1 tech and check out Darth_V8r build and search some of his posts. Thunderstuck also did a very nice write up over there using stock rockers cut into pairs and shimming to achieve lash. I done this on my hydraulic set up as well. Darth uses yella terra rockers from tony mamo. That cam will run and drive about like a SS4 in stock cubes so it should be no issue to tune and will carry out to 76-7800.
2010 C6 JET STREAM BLUE
BOLT ONS TO THE EXTREME, GPI 281cc HEADS, Darth_V8r SPEC CAM, FAST 102 INTAKE, CRANK SCRAPER, QUARTER MASTER 7.25" CLUTCH, RPM 3.90 STAGE II DIF, Z51 Gear Set AND E85 Best ET 10.58 @ 131.8 stock heads and stock cam 453/445 SAE 10.62@134.82 GPI 281CC Heads, SS4 Cam and X1 Intake Best 1/8 6.80@105.75 Best MPH 134.82 |
#14 | |
