Fast Cars and Old Guitars
Drives: 2015 2SS RS (L99, baby!) Join Date: Apr 2012
What a Cool Weather Streak and Amsoil Might Do
I may be suffering from performance delusion, but the weather brought some cold (dense) air to NorCal this weekend and I also changed to Amsoil too. The ol butt dyno picked up 5.45678431856 more horsepower. But I could be slightly off!
![]() Seriously, there was a noticeable difference.
![]() ![]() Drives: 02 Camaro B4C Join Date: Nov 2016
I've been using Amsoil for years in everything from street rods to commercial trucks.
In just about every instance I have seen an increase in fuel economy. Which should also mean an increase in power. That being said a cold snap could also result in more power.
A man's garage is his castle
1969 Camaro SS 1970 Camaro SS 2002 Camaro B4C 2014 Camaro SS Dedicated Track Car 2015 Camaro 1SS 1LE 2008 HHR SS 1996 Silverado Crew Cab Long Bed Dual Rear Wheel |
I mentioned in another thread the other day my 15.1 avg MPG. I drive it like it should only get 15.1 and am happy with that but, I will be curious if the Amsoil improves on that at all. I’ve been a long time fan of Amsoil but it just got harder to find.
Yes, the LS seems to thrive on cold, dense air.
Camaro #4
Drives: 2017-Hyper Blue Metallic-2LTmanual Join Date: Dec 2015
I know when I switched from DEXOS to AMSOIL, I gained a couple of MPG
Don M
Supercharged LGX + 6 speed manual = FUN!! |
![]() Drives: 2013 Camaro Convertible Join Date: Jan 2015
That Cool Air makes everything run great, you can really feel it on bikes.
#6 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2012 ZL1 - #670 Join Date: Jun 2009
What's cool air, we are a couple months away from any type of cool air. I can tell if the weather is good for cars by then way the cold water in the house feels. During our summer months our cold water is warm (90-95) degrees. Both of my cars feel so good during the 70 degree weather, especially the ZL1.
#7 |
![]() ![]() ![]() ![]() ![]() ![]() Drives: 2011 Camaro 2SS LS3 Whipple Join Date: May 2019
It's the cool air. Nothing to do with oil. hot humid compared to cool dry air will make a huge difference. I feel it in my car no doubt easily 5-10% difference. It also makes me lose traction with the cooler roads so it makes it hard to tell sometimes.
#8 |
Those of you who have had older performance cars, could you feel it in those? Or is the LS somehow more able to take advantage of cooler air with its better flow characteristics?
#9 | |
376 cubic inches of fun
Even with a carb engine, there's some power increase when the air density increases, but you would have to be adjusting the carb and changing jets to take full advantage of the denser air. |
#10 | |
#11 |
old school chevy rodder
In the old days you would turn 1/4 turn to 1/2 turn on the enrichment screw of your carb to make use of the denser air by less restriction in the jets pathway and allow more power.
Colder air is always better for making power especially with forced induction etc....
#12 |
It's not because of improved flow, but because of improved engine control to take advantage of basic physics and chemistry; something you will find in the most lowly car today.
#13 |
But I know I’ve read more than once about the increased flow in these motors. Not that I dispute the ECM’s ability to do things like “turn the air/fuel screw” electronically, much better than our old, human feeble attempts to do those things long ago. I guess it’s a combination but a 20 degree temp drop made a noticeable change.
#14 |
Ponies are for girls
January is our coldest month here in southern Arizona, so that's when i run my fastest times. 60* at the track is good to me. And, yes, it's 60 in January. Don't hate! LOL
H&R 1.8/1.7” drop, Overkill 80mm + intake ported by AFS, 1" insulator MACE, Accel Super Coils, THR cai, JET MAF sensor, Hurst shifter handle, GPP strut tower brace, CI ice cube tray hood vents (functional) @SemperFiCamaro
