![]() Drives: 2018 ZL1 Convertible Join Date: Nov 2011
How to improve power on an SS - your thoughts
Helping a friend, not a member, with a 2013 SS. He has added a cat-back exhaust and a cold air intake. He would like a bit more power and throttle response. He does not want to do any further mods to the exhaust system (headers, cat removal, etc). What are the next best steps to add a bit more power and punch? Thanks in advance . . . .
![]() ![]() ![]() ![]() ![]() ![]() Drives: 2011 Camaro 2SS LS3 Whipple Join Date: May 2019
A tune will help. Beyond that you are really going to internals in the engine. camshaft or forced induction. If it's an auto a higher stall converter. Changing to 3.91 gears with help either auto or stick. Headers and a tune is really a good gain from factory. Tune won't do a whole lot without headers. There are plenty of pretty cheap options and headers are a pretty easy install.
![]() ![]() ![]() ![]() ![]() Drives: 2010 SS L99 Join Date: Sep 2018
Tune
Previous PB:11.079 @ 122.99mph.. New setup time: TBD
The 11.079 pass: https://youtu.be/pz27Zq54t_E Build thread - www.camaro5.com/forums/showthread.php?t=555371 |
if your buddy is going to tune the car, either by dyno or plug n play module, they might as well do the headers. One of the bigger gains until you get into forced induction. IMO
Custom TSP Stage 2 Cam/GPI intake Ported Rod Mod /VARARAM CAI/Mishimoto Catch Can/1 LE front & rear sway bars/ engine cover/fuse box custom painted, strut tower brace, Texas Speed LT, Hi Flo Cats, Magnum Tru-X pipe, NGK Spark Plugs, PCM Spark Plug Wire, Painted Calipers, CF Spoiler w/wicker bill. |
Instagram: Sangstah
tune, ported throttle body for throttle response, and gears for more oomph
#6 |
Fast Cars and Old Guitars
Drives: 2015 2SS RS (L99, baby!) Join Date: Apr 2012
The most glaring thing a (remote/email) tune will do is change line pressure parameters in the trans and give you firmer - maybe even a LOT firmer shifts. Performance, not so much without more bolt-ons.
#7 |
and then it never really ends
#8 |
AKA "Beefcake"
Drives: 2023 ZL1 Sharkskin Join Date: Oct 2009
well your friend has a dream like everyone else that just isn't possible.
I want my car to go faster without doing anything that will make it go faster (headers, tune, s/c, turbo, etc). I will add that to my, I want to get skinnier but continue to consume Beer and Pizza friends. |
#9 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 CGM 2SS/RS LS3 Swapped A6 Join Date: Sep 2016
Tune. But that will only take him so far.
Tune and headers are will make the biggest difference at this point, but if he doesn't want headers the tune will still make a big improvement, especially if an automatic.
#10 | |
Drives: 2010 Camaro Join Date: May 2014
Agreed...3:91 will wow up the fun factor and improve the butt dyno. All that other stuff like e tunes, and CAI, PTB..not any real real hp gain except in your head...those are just gateway drugs. |
#11 |
Grumpy Grey-haired Guy
Drives: Camaro, Corvette & Merc C300(daily) Join Date: Aug 2014
Set of long tubes plus CAI & a decent tune = 450-460 hp. VERY noticeable difference under the loud pedal. Tune only won't get you there.
#12 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2SS/RS Join Date: Sep 2008
There is no gains from the cat-back, that is strictly just for sound. He really only has 3 options; ported throttle body will help with response, long tube headers plus hi-flo cats with a tune, a set of 3.91 gears (tune is recommended to correct the speedometer and odometer).
#13 |
![]() Drives: 2014 Camaro 2SS Join Date: Feb 2015
Get a set of gears. Its a great first mod that's less intrusive than modding the engine. Your butt dyno will certainly approve. The car will feel much lighter and accelerate quicker.
#14 |
Great White
Not to hijack but if you have 3:91 gears installed on an auto why would someone install a stall convertor and if so, what kind of convertor? Thanks to anyone with knowledge on this.
