Old 10-04-2019, 12:11 PM   #1
SSkat
SSkat's Avatar
Drives: 2010 Camaro 2SS
Speed engineering connection pipes with TSP headers?
I have texas speed long tubes right now with high flow cats. First i want to know if the speed engineering catless connection pipes will fit. Second will i need to retune when i switch from high flow cats to catless?
SSkat is offline   Reply With Quote
Old 10-04-2019, 01:24 PM   #2
shibbs
Captain Gingerbeard
shibbs's Avatar
Drives: 2012 IOM RS/SS 6MT
Just call TSP and ask them to sell you some off-road connection pipes. They can't be that expensive - they're just a piece of expanded pipe.
Custom ordered 2012 6MT RS/SS on 11/25/2011. Picked up 01/31/12.
Pedders Coilovers, BMR trailing arms and toe-links, Prothane solid poly subframe bushings, JDP Motorsports rear upper control arm bushings, Texas Speed long-tube headers with 2" primaries, modified fully 3" Magnaflow competition catback. CAI cold-air intake. DBA rotors, Hawk pads.
'Hellcat' sounds like some kinda 15 year old furry with liek "I'm a blue fox with wings and magical kawaii powers" kind of sh*t.
shibbs is offline   Reply With Quote
Old 10-04-2019, 02:12 PM   #3
IKILLEDSUPERMAN_ZL1
Drives: 2011 Camaro SS
I had a set of TSP headers and ordered the Speed Eng connection pipes. They fit.
2011 Camaro 2SS, 6.0 iron block forged bottom end, Dart heads, BTR intake, Huron twin turbo kit, Summit stage 3 twin turbo cam, Circle D stage 4 6L90, 3800 FTI converter. BMR suspension, Viking coil overs, Fore triple pump fuel system.
IKILLEDSUPERMAN_ZL1 is offline   Reply With Quote
Old 10-04-2019, 03:03 PM   #4
pyroguy
Started#gottalovethatblue
pyroguy's Avatar
Drives: ABM #832
I'm with shibbs. Why not just order some TSP catless pipes? Are they really that much more expensive?
As for the tune, yes you'll need to retune because you're changing air flow.
Check out my build thread
