Old 10-06-2019, 09:37 PM   #1
StingrayblueSS
StingrayblueSS's Avatar
Drives: 2013 Camaro SS
Vararam DRX review with time slips
AI've been wanting this intake for a while finally picked one up last week. The installation was pretty easy except the silver screws didn't fit the washer bottle motor. My my original maf screws did. Back in September I did a few passes at the track. My best time was 12.700. Saturday I went back the only change was the intake from airaid to vararam plus tuning by Dynosteve.
StingrayblueSS is offline   Reply With Quote
Old 10-06-2019, 11:46 PM   #2
EJSS
Drives: 2010 Camaro SS L99
That's not bad at all, difference of .3 seconds. BUT answer these questions please.
1. What parameters did the new tune change?
2. Was the temperature and humidity similar for both if those days?
I'm wondering if 100% of the gains was the intake or if other factors helped out.
EJSS is offline   Reply With Quote
Old 10-07-2019, 12:17 AM   #3
StingrayblueSS
D/A 9/4 2258
D/A 10/5 2088
Old 10-07-2019, 12:19 AM   #4
StingrayblueSS
I didn't ask Steve what he did I assume add fuel. I sent him a data log and he said changes were needed but didn't say what.
Old 10-07-2019, 11:55 AM   #5
xc_SS/RS
Drives: 2010 Camaro SS/RS
Wait he actually made changes based on a datalog?! I tried a handful of times to get him to make changes to my tune and was always told 'no need, it's good to go!'. It wasn't tuned well.
Good for you to actually get him to tune your car. And good runs.
2010 2SS/RS
Z/28 intake, NW, FAST 102, speed engineering LT's, some exhaust, ATI -10% pulley, GM flex fuel injectors, DSX flex fuel sensor, MGW shifter, HP Tuners, some suspension work, stickers and a little weight loss. 12.63 @113.53
xc_SS/RS is offline   Reply With Quote
Old 10-07-2019, 09:49 PM   #6
StingrayblueSS
Yes he asked me to send him a data log. I've never had a bad experience with him. He's always acted professionally in my experience.
Old 10-08-2019, 10:13 AM   #7
jonathanmoguel
MM.CC
jonathanmoguel's Avatar
Drives: 2010 Camaro 2SS LS3
it looks like you gain a few HP according to your trap speed. if anything probably like 10 hp. your trap speeds are still consistent. only major change is in the 1/8 mile times.
2010 camaro ss: Volant cold air intake, BBK Shorty Headers, JBA offroad midpipes, Diablosport tuned (custom tune), SLP II loudmouth axleback, ZL1 Short shifter, nitrous outlet wet "100 shot"
jonathanmoguel is offline   Reply With Quote
Old 10-08-2019, 12:25 PM   #8
lazerlemonta
lazerlemonta's Avatar
Drives: 2010 C6 1LT
I see track prep being the major factor here. 60 was almost 2 tenths quicker..... If you wanted a real intake test just swap them at the track. I have been involved in real time testing its a lot of fun and you get actual feed back and no guessing.
2010 C6 JET STREAM BLUE
BOLT ONS TO THE EXTREME, GPI 281cc HEADS, Darth_V8r SPEC CAM, FAST 102 INTAKE, CRANK SCRAPER, QUARTER MASTER 7.25" CLUTCH, RPM 3.90 STAGE II DIF, Z51 Gear Set AND E85
Best ET 10.58 @ 131.8 stock heads and stock cam 453/445 SAE
10.62@134.82 GPI 281CC Heads, SS4 Cam and X1 Intake
Best 1/8 6.80@105.75
Best MPH 134.82
lazerlemonta is offline   Reply With Quote
Old 10-08-2019, 05:06 PM   #9
StingrayblueSS
If you use the second and third slip theres only a 10th difference. The other two were bed because of tire pressure and the last one I red lit and i should have thrown that one out.
Old 10-08-2019, 05:15 PM   #10
StingrayblueSS
2 mph in the eight. I have 3.91 gears which affect my trap speed in the quarter
Old 10-08-2019, 05:32 PM   #11
StingrayblueSS
All I know is I've been stuck at 12.7s all year and in glad to be making progress.
Old 10-09-2019, 11:38 AM   #12
go_go_gadget88
go_go_gadget88's Avatar
Drives: 2010 Camaro 2SS/RS ABM 6M
What other mods did you have? Looked like your 60ft was better, that's probably where a lot of the gains are coming from is getting it out of the hole.
2010 ABM 2SS/RS LS3 6 Speed -- Rotofab CAI | Speed Engineering 1 7/8" Longtubes w/ cat Delete | Magnaflow competition catback | TSP 231/246 cam| TSP/PAC .660" Spring Kit | TSP CNC Ported Heads | Bo White PTB | GPI Ported/RM Intake | 3.91's | BC Catch Can | MGW Shifter | BMR 1" Drop Springs | BMR Trailing arms/Toe Rods/Rear UCA Bushings | Pegasus Subframe Mounts
go_go_gadget88 is offline   Reply With Quote
Old 10-09-2019, 02:54 PM   #13
StingrayblueSS
Ported throttle body, headers, 3.91 gears, tune 18" drag radials
