Tune Question!
2013 2SS/1LE
Disclaimer:I'm young and still learning. I've got long tube headers(runs pretty rich w/o tune) and getting ready to install my TSP Stage 3 Cam. Would a SCT tuner work well enough to make it drivable or is a dyno absolutely required after installing a Cam that size/in general? Thanks in advance! |
Ponies are for girls
I'd say you'd definitely want a dyno tune, so they can tune as it runs. Otherewise you'll be having to retune over and over for a while.
H&R 1.8/1.7” drop, Overkill 80mm + intake ported by AFS, 1" insulator MACE, Accel Super Coils, THR cai, JET MAF sensor, Hurst shifter handle, GPP strut tower brace, CI ice cube tray hood vents (functional) @SemperFiCamaro
![]() ![]() Drives: 2010 SS/RS M6 BIG cam Join Date: Mar 2016
Dyno or custom email tune , SCT only good for completely stock motor/car.
You could use a SCT unit to load a custom email tune. But if you have a dyno tuner to go to defiantly go to them for the tuning
BIG cam ...... 305 45 18 Mickys ...... BMR suspensions
![]() ![]() ![]() ![]() ![]() ![]() Drives: 2011 Camaro 2SS LS3 Whipple Join Date: May 2019
call Jannety. I use the SCT tuner and he uses it. He sent me a tune that was great after my supercharger install. It ran great. I had it dynotuned anyway but it was 95% with his emailed tune.
Awesome, thanks all!
| Tags |
| #cam, #tuning |
