Old 10-08-2019, 02:48 PM   #1
awdmofo
V6 banger
awdmofo's Avatar
Drives: 2016 Lexus CT200H
secondary cat removal = more HP?
Just curious if anyone ran a straight pipe in place of the secondary cats on a LFX and saw any power gains. Is it much louder or are there any downside to doing this? such as CEL or lost of TQ etc.... Thanks!
2016 CT200h (daily)
2017-2020 V6 (currently looking to buy)
2013 LS 6-speed (SOLD)
Elite E2 catch can, CAI intake, 2.5" SLP Loudmouth II mufflers with no resonators with an X pipe, Kenny Racing ported TB, Jacfab spacer and ported manifold and Accelerated Racing E85 octane dyno tune = 300WHP
Special Thanks to... Jason@JacFab, ChibBlackSheep, Kenny Racing & Accelerated Racing (use to be in) Rancho Cucamonga CA.
awdmofo is offline   Reply With Quote
Old 10-08-2019, 04:07 PM   #2
ChibiBlackSheep
ChibiBlackSheep's Avatar
Drives: 2012 2SS/RS, 1968 SS
Is there a reason you don't want to just get solo high-flow downpipes instead?
I think you'd benefit a lot from getting that new pipe + high-flows with resonators. If you just straight pipe the secondary, it might get a little droney.
LS3 Crate Engine Swap | CSP Custom Cam 232/240 .615/.615 113 +3 | Stainless Power LT Headers | Z28 Intake | Borla S-Type Exhaust | FTI Triple-Disc Billet 3200 Stall
2012 Camaro 2SS/RS | 1968 Camaro SS | 2020 Cadillac CT5 Premium Luxury | 2021 Spark LS
ChibiBlackSheep is offline   Reply With Quote
Old 10-08-2019, 10:47 PM   #3
DSX_Camaro
DSX_Camaro's Avatar
Drives: 2013 SW 2LT/RS LFX/AY6
I did at one point. It isn't much louder but while you do get "some" more volume, the primary cats are bigger and more prominent by extension. Real power is in high flow cats or catless downpipes. (After having them both in my hands I'm still not positive the stock cat pipes are 2.5" compared to catless downpipes but I assume they're the same)
DSX_Camaro is offline   Reply With Quote
Old 10-09-2019, 03:14 AM   #4
awdmofo
V6 banger
awdmofo's Avatar
I'm cheap . but seriously I can get a straight pipe with flanges to bolt back the cats back to stock for super cheap. I thought before I get the 80mm tb port job on my manifold and get it tuned for E85 id would be interested in seeing if it was worth deleting those cats. If I hate the sound I'd just bolt up the cats again. They are only like 6 inches long I wouldn't think they could make the car that much quieter . But if it freed up HP that anyone else has seen on a dyno i'd be game to try it.
2016 CT200h (daily)
Old 10-09-2019, 08:51 AM   #5
ChibiBlackSheep
As mentioned above, your front cats are still going to restrict.
I honestly think the downpipe replacement is your best bet for the most power.
They are practically the headers of the LFX world, it is unfortunate they are a little expensive.
Old 10-10-2019, 02:58 AM   #6
awdmofo
V6 banger
awdmofo's Avatar
Yea not worried about it getting a little louder, more worried about not gaining any HP from doing it. I know ARH are under $600 for high flow cats, and the Solos are around $800 I believe. Just trying to get a little more HP before the dyno in a few weeks. I guess I could leave that as my final upgrade If I decide to keep the car much longer. Outside of the SLP crank pulley, I've bolted on everything you can get for these V6s .
Yea seems like that would be the only restriction i'd have left in the whole engine. Sucks they arent cheaper but maybe i'll just be happy with 305-308RHWP after i get it corn powered . Or if I keep it longer i could go with Cams, DP and a new clutch. really max out the V6 power.
2016 CT200h (daily)
Old 10-20-2019, 12:25 AM   #7
Red Beard
Instagram @redbeardfifty
Drives: Chevy colroado, Gmc yukon
What sort of gains are made with hi flow cats or catless? I’ve been debating this as my next step, but haven’t found any info.
Red Beard is offline   Reply With Quote
Old 10-21-2019, 11:46 AM   #8
DSX_Camaro
DSX_Camaro's Avatar
The more cats you remove the more you will notice it. Secondary cats removed with only primary stock cats may have an improvement, high flows or catless would give an improvement you could definitely feel, each with a greater improvement than the option before. At most on a completely stock vehicle it could be a max of 15whp. But everything matters if you're chasing peak numbers.
Old 10-22-2019, 02:09 PM   #9
awdmofo
V6 banger
awdmofo's Avatar
DSX you running any cats?
2016 CT200h (daily)
Old 10-22-2019, 02:44 PM   #10
DSX_Camaro
DSX_Camaro's Avatar
Negative. Catless downpipes. But I also have the Magnaflow resonated x.
Old 10-24-2019, 06:00 PM   #11
awdmofo
V6 banger
awdmofo's Avatar
yea, i'm not running any resonator so thats why i cant run catless. Highflows maybe, but i'll see where my dyno numbers are at once i get the E85 tune.
2016 CT200h (daily)
