Old 10-08-2019, 03:20 PM   #1
MIKZ28
Drives: 2019 Camaro ZL1 2004 Pontiac GTO
Softer springs for Z/28
Just wanted some thoughts on replacing the suspension springs on my 2015 Z/28 to stock SS springs or after market to get a smother ride. My Z is a DD and I never track it. I bought the car for it's LS7 and rarity. I enjoy driving unique cars that nobody else has. I have never seen another Z driving around where I live. (northern IL). My doctor says I must sell the Z because it is hard on my neck because of the very harsh suspension. Most of the roads around here are very rough. I have had severe neck pain since several months after I started driving my Z as a DD. I under stand that you purists out there are going to tell me BUY A ZL1 for DD. But I want to keep my Z and my mind is made up. I will keep the Z/28 parts so it can go back to stock if needed. So I want to keep the F1 struts if possible. Want softer springs the same ride height or possibly an inch higher if needed for travel. Just looking to get some good advise on what springs to buy to meet my objections. I owned a 2010 Camaro SS I drove as a DD for 8 years and never has any neck pain. If I could modify my Z to ride and handle like my SS did I would be pleased. Thanks.
MIKZ28 is offline   Reply With Quote
Old 10-08-2019, 03:45 PM   #2
608RS
608RS's Avatar
Drives: 2015 2ss
you're not too far from NicKey Performance up in Loves Park, i'd give them a ring and see if they can help you out. i'm sure they can figure out a way to make it work.
NicKey
608RS is offline   Reply With Quote
Old 10-08-2019, 03:58 PM   #3
Silveradoss573
Banned
Drives: Camaro 1LE
I'd say you're looking at a full set of springs and struts/shocks. My 1le is really stiff and no way I could ever use it as a daily driver. I'm guessing a SS setup would probably get you what you're looking for...maybe?
Silveradoss573 is offline   Reply With Quote
Old 10-08-2019, 04:50 PM   #4
NastyNate'sZ28
Drives: Chevy Camaro Z28
Pretty sure guys have swapped out the factory Struts for a KW coilover system. Guy on Instgram "the_baddest_z28" would know more if you can look him up. With the KW suspension I would guess you could really dial in the ride comfort better.
NastyNate'sZ28 is offline   Reply With Quote
Old 10-08-2019, 04:55 PM   #5
MX621
MX621's Avatar
Drives: 2014 z28
Your gonna have to Ditch the dssv’s is you need a smoother ride. Softer spring won’t help the fact they are designed to prevent body roll at race track speeds. The shock is hydraulically limited to do just that, just the design intent. I’d say SS struts/shocks with a lowering spring will get you the desired feel and ride hight your after.
MX621 is offline   Reply With Quote
Old 10-08-2019, 06:01 PM   #6
j o n
j o n's Avatar
Drives: 2015 Z/28 #0058
Get coilovers. Dssv struts/shokcs are the issue not the springs.
He has kw coilovers
https://instagram.com/carbonz28?igshid=1dsijl3bhmrhb
https://www.instagram.com/p/BEj2A6jn...=15p95v98k2rhy
Current:
- '15 Z/28 #0058 | White | A/C | Speakers | Michelin PS4S 305/30/19's
- '22 Ridgeline RTL | White | Ebony, '22 CR-V EX-L Hybrid | White | Ebony
Sold:
- '15 Z/28 #0048 | White | A/C | Speakers | Michelin PS4S 305/30/19's
https://www.instagram.com/__jon__athan__/
Last edited by j o n; 10-08-2019 at 06:03 PM. Reason: https://www.instagram.com/p/BEj2A6jnRYt/?igshid=15p95v98k2rhy
j o n is offline   Reply With Quote
Old 10-08-2019, 07:18 PM   #7
MIKZ28
Thank you all for the great suggestions. I think SS springs and struts will be the way to go. Maybe some after market springs to get the slightly lower stance the Z has over the SS. You think a 1" drop all around will be about right? Which is the best lowering springs? hotchkis? Eibach? Many thanks!!!
Old 10-08-2019, 07:21 PM   #8
Mark_Z28
Drives: Black 2015 Z28 #457
Motion control suspension(MCS) has a 1-way non remote reservoir setup that is supposed to work with our cars. I think its like the DSSVs that use a 2.5 inch spring as well so pretty much any spring that size will work.
Mark_Z28 is offline   Reply With Quote
Old 10-08-2019, 07:41 PM   #9
69L48Z27
69L48Z27's Avatar
Drives: 2015 Z/28; 1969 Camaro SS
I think you should get a new doctor! Get rid of the car?!?
69L48Z27 is offline   Reply With Quote
Old 10-08-2019, 09:12 PM   #10
j o n
j o n's Avatar
Good review on DSE springs https://www.camaro5.com/forums/showt...&highlight=Dse
More pics
Current:
Sold:
Old 10-09-2019, 07:37 AM   #11
CamaroCracka
CamaroCracka's Avatar
Drives: 2010 Turbo LS3
This.
When you start messing with a proven suspension combination, you can turn the car into a very fast looking grocery getter. The guys replacing the spring/shock combos on the Z28 are generally going to something adjustable. The sway bars on the Z28 are smaller because the spring/shock combo is so stiff. Softer springs will bring more body roll.
Old 10-09-2019, 09:01 AM   #12
MrRaZ28
@MrRaZ28
MrRaZ28's Avatar
Drives: 2014 Z28 #80
Well, OP DID say they don't track it and only DD it... so grocery getter falls under that designation.
MrRaZ28 is offline   Reply With Quote
Old 10-09-2019, 11:57 AM   #13
MIKZ28
Thanks again for all your help. I think I will go with the DSE speed kit 1 #033023 with Monroe stock style struts. I have Monroe struts on my 2004 Pontiac GTO and they have been flawless. Plus they much cheaper than GM. I may need to also order some small mounting parts as it seems Z/28 dust boots and several other mounting parts are different than the SS.
Old 10-09-2019, 12:28 PM   #14
j o n
j o n's Avatar
Monroe struts/shocks?
At least put koni's oranges on the car. The DSE spring spring rates can beat up the struts/shocks.
https://konimarket.com/products/2010...ront-right-563
Current:
Sold:
