Old 10-08-2019, 05:25 PM   #1
SYNGSS
SYNGSS's Avatar
Drives: 2011 Camaro 2SS/RS 6 Manual
Removing the front sway bar?
I'm looking at getting the Lakewood 70/30 front drag struts and the manual for the struts suggests removing the front swaybar at the dragstrip and re-installing it for street use. Has anyone here tried this!
Thanks
[Dyno Results] 684rwhp 602.84Pktq at 6600rpm. Mods: too much to list.
SYNGSS is offline   Reply With Quote
Old 10-08-2019, 06:32 PM   #2
Chris49066SS
Chris49066SS's Avatar
Drives: 2010 SS L99
Thanks
I removed mine almost a year ago and have no issues. Easy less weight on the nose of the car, nothing much different day to day driving. I drag only, I don't track it.
Previous PB:11.079 @ 122.99mph.. New setup time: TBD
The 11.079 pass: https://youtu.be/pz27Zq54t_E
Build thread - www.camaro5.com/forums/showthread.php?t=555371
Chris49066SS is offline   Reply With Quote
Old 10-08-2019, 07:05 PM   #3
stratman2SSRS
stratman2SSRS's Avatar
Drives: Lingenfelter Camaro
You can either take it out, which involves loosening the motor mounts and jacking the engine up to get enough clearance to get it out, OR you can remove the links, and just zip tie the sway bar from the holes in the end of it to the holes on the body that are close to hold it up into place.
stratman2SSRS is offline   Reply With Quote
Old 10-08-2019, 07:37 PM   #4
SYNGSS
SYNGSS's Avatar
Did you remove yours? If so did you find the car handled noticeably different?
Old 10-08-2019, 09:03 PM   #5
Chris49066SS
Drives: 2010 SS L99
I didn't need to do anything with the motor mounts or raise the engine when I took mine out. Not necessary, you just hafta play with it and fanagle it for a few minutes, its no big deal, just sort of annoying. Had it out in about 10 minutes just jacking the car up.
I have driven it and made sudden jerks to the wheel left and right, and it just doesn't have that much of an effect, its not like your car is gonna tip over or something. The front end does feel like it raises a bit more on the launch, which hints at more weight transfer to the rear. I feel that the effect would be better maximized with a good shock and strut combo set up for drag racing though to take better advantage of this. Just my thoughts
Old 10-09-2019, 11:42 AM   #6
SYNGSS
SYNGSS's Avatar
Thanks Chris
Not worried about normal street driving it's how it handles at the top end of the track at 125+mph. Our local dragstrip has some minor bumps at the top end and somewhat of a short shutdown, so we have to get on the binders quick enough but yet not too hard on the brake pedal to the point of unloading the rear suspension.
Old 10-09-2019, 09:56 PM   #7
Chris49066SS
Drives: 2010 SS L99
Thanks Chris
I can understand that. Well, I still feel glued to the track when I am making passes at 120mph so i guess give it a try first by disconnecting the links and zip tying them and if its not something that bothers you, take it out if you want.
Old 10-10-2019, 08:59 AM   #8
stratman2SSRS
Zip tying it up definetley helps with weight transfer letting the front come up.
I ended up taking it out for a little weight savings. I'm not driving on the street much.
Old 10-10-2019, 09:05 AM   #9
joshnmn
2&THEHIT
joshnmn's Avatar
Drives: 5th Gen Camaro; 5th Gen Ram 3500
while this is all very informative, I'm just here to say that Synergy SS is en fuego
very nice!
joshnmn is offline   Reply With Quote
Old 10-10-2019, 10:16 AM   #10
SYNGSS
SYNGSS's Avatar
very nice!
Gracias
Old 10-10-2019, 10:25 AM   #11
SYNGSS
SYNGSS's Avatar
Thanks Stratman I'm going to take your and Chris's advice on that one and zip tie the bar after the links are removed and see how it work out.
On another note: I'm toying with the idea of doing the 15" wheel conversion from Carlyle as it seems to be more street friendly then the BMR kit. I know you have done this conversion so when you do drive it on the street how do find the ride quality over the 20's?
Old 10-10-2019, 03:32 PM   #12
62nalide
62nalide's Avatar
Drives: 2013 SS
I removed mine hours after buying the car back in 2013
62nalide is offline   Reply With Quote
Old 10-10-2019, 03:39 PM   #13
bct10985
Drives: 2010 2SS LS3, 2013 duramax
Yea i sawzalled mine in half and it went in the trash
ECS Ysi-B, cam, Tsp 2" longtubes, Squash dual pumps, Id1300s, meth, 4L80e, FTI 3600, ZL1 3.73 diff, BMR suspension, 15" conversion, weld rts mt 275 et street R. 9.6@147mph
bct10985 is offline   Reply With Quote
Old 10-10-2019, 04:43 PM   #14
SYNGSS
SYNGSS's Avatar
Just have to ask! do you drive on the street with your 15's and if so how do you find the ride with the Carlyle kit? Noise,Rattles,Ride quality?
I don't want to make the same mistakes I made with my other Camaro when I went with a 4 link coilover setup. The car drove like a dump truck full of metal
Thanks
