Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > General Camaro Forums > Regional Forums > USA - Mid-Atlantic > Local Marketplace
Old 10-10-2019, 08:32 AM   #1
Abnav8r
Drives: 2014 LS
2014 LS Camaro OEM and Non OEM parts for sale!
2014 LS Camaro 14k miles take off parts for sale: GoodYear
All items to be sold plus actual shipping cost to your zip code unless doing local pick up.
Complete OEM front and rear rotors, calipers, Pads, brake lines and master cylinder
$150 for everything
OEM air intake box with filter
$25 or best offer
OEM 72mm PORTED throttle body
$100 SOLD
OEM "Silver Ice" Wheels and tires (set of four). As stated above, wheels and tires have only 14k miles on them and are in excellent condition! No curb rash, no damage and run true. BF Goodrich tires.
$400 245/55/R18
SOLD
OEM Coil Springs and sway bars, front and rear
$50
NON OEM Parts:
AutoCal with OVERKILL tune for my Camaro as equipped. (Auto trans) PM me for list of upgrades.
$100
SOLD
Brand New Eibach rear sway bar. 32mm. Part # 38162.32 Fits SS rear. $250 new.
$125
SOLD
REAR:
OE SS bar:
24 mm (0.9 in) solid
OE ZL1 bar: 28 mm (1.1 in) solid
OE SS bar rate: 21 N/mm (119 lbs/in)
OE ZL1 bar rate: 49 N/mm (278 lbs/in)
OE SS bar weight: 5.5 kg (12 lbs)
OE ZL1 bar weight: 7.5 kg (16.5 lbs)
Eibach bar: 31.75 mm (1.25 in) Tubular, adjustable
Eibach measured bar rate: 2 position adjustable
P1 = 46 N/mm (262 lbs/in)
P2 = 60 N/mm (337 lbs/in)
Eibach bar weight: 5.3 kg (11.5 lbs)
Bushings: New urethane bushings with grease grooves
End Link: OE with new urethane grommets.
Approximate installation time: 1.0 hr
MFG Model Year Front Rear Part# Sugg. List ETA CHEVROLET Camaro SS 2013 29mm 31.75mm 38162.320 $579.00 Available CHEVROLET Camaro ZL1 Coupe 2012-13 29mm 31.75mm 38162.320 $579.00 Available CHEVROLET Camaro ZL1 Conv. 2013 29mm 31.75mm 38162.320 $579.00 Available
Complete Solo Performance Mach-X-LFX Cat-Back exhaust. Installed on my car for about 200 miles. Wife didn't like it! $962 new
$450
SOLD
Abnav8r is offline   Reply With Quote
