Stock Bottom End LS3 5.98 1/8 mile
Got the car lined out and made a clean pass. Still need to tighten up the converter and get a bigger Intercooler, hoping to go E85 at the same time. Should be a little faster next year.
SBE LS3 Texas speed blower cam GMPP heads F1A94 ProCharger on 17lbs 93 with Meth injection TH400 Tuned by Adam Blevins with Blevins tuning https://m.youtube.com/watch?v=LP_Hx8yK5Kc
5.98 @ 115mph
![]() Drives: 2012 camaro ss ls3 Join Date: May 2014
what gear u running and what size converter if u dont mind me asking
Drives: 2013 Sparkly Red One Join Date: Dec 2018
I want 15s.
#4 | |
The converter is a custom spec 10.5" from Dusty Bradford
5.98 @ 115mph
![]() ![]() ![]() ![]() ![]() Drives: 2010 SS L99 Join Date: Sep 2018
What compression and combustion chamber size and injector are you running? I am shooting for a similar build to yours
Previous PB:11.079 @ 122.99mph.. New setup time: TBD
The 11.079 pass: https://youtu.be/pz27Zq54t_E Build thread - www.camaro5.com/forums/showthread.php?t=555371 |
#6 |
8.60 @ 157 @ 4200lbs
Awesome
Congrats
2010 camaro twin turbo 8.60 @ 157 full weight 4200
#7 |
Trouble_SM
Drives: 17' Summit White ZL1 Join Date: Jan 2015
Wow! I had a similar pass this last Friday night. Went 5.91@119.72 in the 1/8 with my SBE LS3 TT 1LE.
#8 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 12 camaro ss, 72 chevelle, 91camaro Join Date: Dec 2013
Congrats man!
#9 |
Solid numbers
#10 | |
![]() ![]() ![]() ![]() ![]() Drives: 2013 Camaro SS Turbo Join Date: Apr 2014
What trans and rear end?
#11 |
Writer
Drives: 2010 SS / 1967 Camaro Join Date: May 2009
Nice results, what RPM are you shifting that combo at?
PROJECT HEAVY CHEVY
Camaro Now: Mods for the Masses Part I | Part II 13.15@106 1.95 | 100% Stock 12.37@112 1.85 | + Kooks Headers/Cats + 20" 555R + CAI + BW TB + UDP + Tune 12.06@113 1.70 | + CD 3200 + 18" NT05R + RCR Intake + NE OTR + GPI Tune 11.84@115 1.59 | + 3.91s + Race Star 17x7 Fronts 10.90@125 1.47 | + GPI VVT Cam + BW Ported Heads + CD 3800 |
#12 |
Trouble_SM
Fif_gen - Mine is an RPM stage 5 4L80e and zl1 3.73 differential.
#13 |
I haven’t had any issues with the rear. I did the JRE posi mod a while back and it seems to hold up pretty good.
John I was shifting about 7100
5.98 @ 115mph
