![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2SS/RS L99 BLACK Join Date: Apr 2010
4L80E controller
I am curious as to what controllers those with 4L80E's are using .
![]() Drives: 11 camaro Join Date: Mar 2017
I've been running US shift quick 4 for a couple years no issues. Sets up on a laptop.
2011 1SS/ Thompson mtrsprts 416,Katech rotate assembly and cnc ls3 heads. Ferrera st. valves,BTR 685 Spr. F1A Procharger,3.70 pulley on 12 rib.Holley aux fuel pump,ZL1 fp and fpcm,dual alky control,Vmax TB,DSX E-85 sensor, fic1300 inj.Lsxperts custom cam,melling OP,mishimoto dual pass HX, ARH 2" headers, MD 4l80e, FTI 3200 stall,3:73 zl1 cradle, BC coil overs ,pfadt sway bars, EBC brakes and slotted rotors: 843rwhp tuned by LSXPERTS
Drives: 2013 Sparkly Red One Join Date: Dec 2018
PCS TCM2000
I'll look into both of those mentioned above but also had a couple of others in mind, one is distributed by Hughes, where I got the transmission from. I'll be deciding on one by Monday, it's the last component needed to get the Buick mobile. Any other suggestions I can look at?
After some research and the fact that Hughes Performance also uses the US Quick Shift 4 I'll be going with that as long as it's compatible with my set up. I'll be contacting them tomorrow with a few questions and ordering it.
