Old 10-26-2019, 10:37 AM   #1
ttshovel
ttshovel's Avatar
Drives: 12 camaro ss, 72 chevelle, 91camaro
Closing in on 7 second 1/4 sbe
First time leaving in first gear after a 4 link bar change. Got some tire shake, ran it out on 29psi. Put some more power in the hit and had to pedal it before the 60 and still went 1.18, ran it out on 31 psi.
I'm still on stock front struts, sbe 6.0, and stock untouched casting 821 heads. 3420 raceweight. Front end limiters are in my future
ttshovel is offline   Reply With Quote
Old 10-26-2019, 11:28 AM   #2
Neumatic
Drives: 2010 Camaro 2SS M6
Your car is so damn impressive. Ohio representing.
Neumatic is offline   Reply With Quote
Old 10-26-2019, 11:49 AM   #3
ttshovel
ttshovel's Avatar
Thank you man!
Old 10-26-2019, 11:51 AM   #4
graf101
Trouble_SM
graf101's Avatar
Drives: 17' Summit White ZL1
Damn! Thing is impressive as hell!������
graf101 is offline   Reply With Quote
Old 10-27-2019, 09:26 PM   #5
Batmanntexas
Batmanntexas's Avatar
Drives: 2012 Camaro SS (2SS)
You going to put a Lexan window in the floor?? Haulin' a$$!!! Great work!
745RWHP/634RWTQ on 93 @ 10psi
806/676 on E85 @ 10psi
Currently @15-16psi....
COTW 9/8/14
Batmanntexas is offline   Reply With Quote
Old 10-30-2019, 09:13 PM   #6
crankpin
Drives: 2010 Camaro
Wow that is amazing! Do you have any video? How responsive is that big turbo? It seems like it would be pretty decent but I always wonder.
crankpin is offline   Reply With Quote
Old 10-30-2019, 09:24 PM   #7
ttshovel
ttshovel's Avatar
I have built in bump box. For some reason it quit working so just spooled it fully staged. The turbo was spec'd for 40x cubic inches and the hotside was built for that as well so it's laggy if you're not on the transbrake
Old 10-31-2019, 10:03 PM   #8
crankpin
Drives: 2010 Camaro
Damn thats an awesome setup, good work! I have an LS3 with twin s257s and am going to put an S594 on it, with a manual, so mine will be really laggy, but its a standing mile car more so it might be ok. I might wind up with a 427 or 441 in the end then it wont be an issue.
Keep us updated on how it goes getting into the 7s!
