Old 10-27-2019, 11:44 PM   #1
race24x
Drives: 80 Z28 - 93 Z28 - 14 Camaro SS-RS
Car is cutting out at 3psi Kraftwerks
Hi guys I have a 2014 Camaro SS with a Kraftwerks Supercharger. It has been running excellent. I drove it today and when it gets up to about 3psi of boost it feels like the ignition is cutting off and then back on and then off back and forth. Wondering if anyone has experienced something like this. I will add my mods below. I think the DSX kit turns on the fuel pump at 3 psi so I tried unplugging it because it goes between the MAP sensor and the ECM, but that didnt help. Could it be something in the blow off valve forcing the TB shut on boost? It really feels like the ignition is switched off for a fraction of a second and turned back on. It was raining like hell today as well. This is the first time this has come up. I was not running E85 when this happened.
40k LS3 M6 SS
Kraftwerks SC 70mm pulley
3 Bar MAP sensor
850 FIC Injectors
DSX Aux Fuel pump
DSX E85 sensor
race24x is offline   Reply With Quote
Old 10-28-2019, 07:03 AM   #2
eLeSthree
Drives: 2011 Camaro SS 6sp
Have hp tuners? Or someway to data log?
Has the car been calibrated for that MAP sensor? Are you sure it's been tuned right for Flex fuel?
Can you post your tune file?
If the answers are no, then you may have to talk to your tuner.
2011 Camaro SS---SOLD
TMS Dart 427 FED M311s, ESS Tuning G4 Blower, DSX Triple FP Assembly, DSX FF, FIC1300, Mcleod RXT 1200HD, Edlebrock Pro Flo XT
1158whp 1017wtq.
2010 CTS-V A6 - "Stock" SOLD
630whp 658wtq
2024 F-150 RCSB 5.0 4x4
waiting for tunes...
eLeSthree is offline   Reply With Quote
Old 10-28-2019, 11:46 AM   #3
race24x
I am sure it was tuned correctly as it has been working right for about 3 months. With the Flex Fuel and without. I wonder if I should replace the MAP sensor as it really seems to be linked to the boost. It is tuned using HP Tuners, but I think I need a special license to data log right? My tuner has it I am sure, but he is in NH which is 2 hours away. Its odd that this just started happening suddenly. I was low on fuel and stopped. The station only had 91 so I put in 2 gallons to get me to my home station. I noticed it a little tiny hitch when I was getting on the Highway. I thought maybe bad fuel so I went to my station and put in 6 gallons of 93. Issue was still there and I tried to get it to go past that spot thinking maybe TPS issue, but no go. Once it hits around 3psi it shuts down and comes back on hits 3psi does it over and over like a really bad skip. The other anomaly was rain. It was raining pretty hard and I dont normally take the car out in the rain.
Old 10-28-2019, 12:52 PM   #4
600hp-lpe
Drives: 2010
have you looked to see if the vehicle has any codes in the computer?
VIP auto parts will scan for free..
you could try pulling the battery terminal - after you look for codes.
600hp-lpe is offline   Reply With Quote
Old 10-28-2019, 03:53 PM   #5
Greenhornet2
Greenhornet2's Avatar
Drives: 2011 Camaro 2SS LS3 Whipple
strange. How is your battery? I know those can do some weird shit when they are low. Will it rev if you aren't boosting or will it cut at a certain rpm as well?
Greenhornet2 is offline   Reply With Quote
Old 10-28-2019, 04:10 PM   #6
race24x
It seems to rev in neutral fine I havent pulled the terminal off, but it does start fine and runs perfect up to when it starts making boost. I could try a new battery I guess. I have a code reader, but havent seen any codes. I was hoping this wasnt a one off thing and someone else had seen and fixed it
Old 10-28-2019, 05:07 PM   #7
760bowtie
760bowtie's Avatar
Drives: 2014 1SS/RS, 2018 Silverado CC
It happened to me once after pumping 91. Once I went back to e85 it was back to normal.
AGP 57/57 turbos and Dual Pump System, NA Cam, McLeod RXT clutch, MGW shifter, ZL1 Rear End, BMR Trailing Arms/Toe Rods, Pegasus Solid Cradle Bushings 10.7 @140mph M6
760bowtie is offline   Reply With Quote
Old 10-28-2019, 05:09 PM   #8
race24x
No way and you had the same exact SC right? I dont run E 85 all of the time, only when I want to go drag race etc. it runs great on 93 normally. I have really only put 20 gallons of E85 through it
Old 10-28-2019, 05:32 PM   #9
760bowtie
760bowtie's Avatar
Yea it was when I had the kraftwerks kit. I mainly run on e85, I only pump 91 on emergencies to get me to the next e85 pump. It only happened once but once it had e85 in it, the car was back to normal.
Old 10-28-2019, 11:55 PM   #10
race24x
I am going to try running the fuel out of it and adding some Aviation fuel. E85 is hard to get and 11 bucks per gallon.
Old 10-31-2019, 03:44 PM   #11
race24x
So I ran the fuel out and at first I thought the issue was fixed. I drove it as far out of gas as I dared and had 5 fresh gallons of 93 octane in the trunk. Put in the 5 gallons and after about 2 or 3 miles stepped on it and it seemed much better. Drove almost 40 miles and tried it again and it popped still but not as bad. I am a little frustrated since I thought I had the issue solved. I want to try and get some E85 but its harder to get here. I just cant figure out why I would see this issue after running perfect all summer on 93.
Old 10-31-2019, 03:51 PM   #12
ChibiBlackSheep
ChibiBlackSheep's Avatar
Drives: 2012 2SS/RS, 1968 SS
I see you are in maine. Did you guys already switch over to winter blend?
LS3 Crate Engine Swap | CSP Custom Cam 232/240 .615/.615 113 +3 | Stainless Power LT Headers | Z28 Intake | Borla S-Type Exhaust | FTI Triple-Disc Billet 3200 Stall
2012 Camaro 2SS/RS | 1968 Camaro SS | 2020 Cadillac CT5 Premium Luxury | 2021 Spark LS
ChibiBlackSheep is offline   Reply With Quote
Old 10-31-2019, 09:34 PM   #13
Greenhornet2
If you filled a can with 5 gallons of 93 you likely only got 3 gallons of 93. I always try to do a full fill because the guy before you likely got 87 and you're getting his leftovers too. Maybe try a full tank of 93 with octane booster or something and see if it goes back to normal.
Old 10-31-2019, 11:59 PM   #14
race24x
Black Sheep - Not sure, but it shouldnt run that bad I dont think.
Green Hornet - Good point it does seem better than it was. I was thinking of adding some Heet to the fuel for water and then some octane boost or aviation fuel.
