Old 10-28-2019, 10:15 PM   #1
Teeth
Teeth's Avatar
Drives: 2010 Chevrolet Camaro SS
Did an entire exhaust delete, catback
Reposting this from the exhaust forum, with pics
Cut off the exhaust from the O2 sensor to make it stupid loud, but still in legal limits for my state.
But I guess I should get it tuned yeah? Engine light is on. Also the keyfob doesn't start the car. There's a click of the ignition, but nothing, needs manual start.
Any thoughts?
Teeth is offline   Reply With Quote
Old 10-28-2019, 10:40 PM   #2
MrChrisLS3
Drives: 2018 1SS M6
Engine light is on because the o2 sensor is exposed to outside air. It's probably reading lean condition.
Remote start will not function if you have a CEL, which you do.
There's a good chance you're going to get carbon monoxide inside the car if the exhaust is dumping out right there.
MrChrisLS3 is offline   Reply With Quote
Old 10-28-2019, 10:43 PM   #3
Teeth
Teeth's Avatar
Oh. Well that doesn't sound that bad? I guess I could make custom pipes for side exhaust like a Viper or something.
Old 10-28-2019, 10:55 PM   #4
_Onyx_Wolf_
Onyx_Z7 <— Instagram
_Onyx_Wolf_'s Avatar
Drives: 2013 2ss 1le
U need at very least some turndown tips so if you backfire you don’t catch something on fire
_Onyx_Wolf_ is offline   Reply With Quote
Old 10-28-2019, 11:09 PM   #5
Teeth
Teeth's Avatar
That's what I was missing, I knew it, thank you.
Old 10-28-2019, 11:22 PM   #6
lemontwist
lemontwist's Avatar
Drives: 12 2SS/RS L99,11 2SS/RS LS3totaled
that was a high dollar loud enough exhaust you just cutoff
why not just take off the caps by the mufflers??? the hot exhaust is going to cook the tranny fluid.
to each his own.......a guy at work has a charger 5.7 he did a "muffler delete" i think it sounds like a car the muffler fell off of LOL.
lemontwist is offline   Reply With Quote
Old 10-28-2019, 11:30 PM   #7
StingrayblueSS
StingrayblueSS's Avatar
Drives: 2013 Camaro SS
You could have unbolted the first set of clamps instead of instead of cutting where you did.
StingrayblueSS is offline   Reply With Quote
Old 10-29-2019, 12:00 AM   #8
Teeth
Teeth's Avatar
It was an old exhaust from a previous owner. Kinda not worth much now lol, maybe a few years ago.
I didn't think about that one, took it to a muffler shop and they cut it off where I asked, should have thought about it more. Now I'll just have to weld something on it.
Old 10-29-2019, 12:13 AM   #9
InFiD3ViL
InFiD3ViL's Avatar
Wow. I hope you didn't just give that old exhaust to the shop. That is not a crap exhaust. That is a fully stainless steel cat back Borla system with X pipe and J-pipes. You could have simply pulled the mufflers off at the rear and either replaced them with straight pipes AFTER the J Pipes and got the loudness you want but with a rear exit and no drone. The J Pipes are to eliminate the cabin drone that you are going to surely get now. Assuming you are not already tuned, that thing is going to sound like a farting monster when AFM/DOD engages.
Like said above, if you have a check engine light on you cannot remote start the car. You will need to get those rear O2 sensors turned off in a tune.
But, if you like it and can tolerate that drone and are happy with it...Your car your choice.
Old 10-29-2019, 12:17 AM   #10
Teeth
Teeth's Avatar
I'm fine with the drone and everything! I did not give the pipes to the shop though, just left them there for a bit until I can find a way to pick them up.
Old 10-29-2019, 12:36 AM   #11
Danial
Danial's Avatar
Drives: 2013 SS/RS, 2015 Camaro SS/RS Vert
Everyone has their own dream for their car. I'm sure I've done a few things over the years that made people scratch their heads but hey, that's life.
Danial is offline   Reply With Quote
Old 10-29-2019, 01:52 AM   #12
Ashen L99
Ashen L99's Avatar
Drives: Ashen grey, 1SS, L99
Cut the secondary cats off, weld in some straight pipe where they were, then undo the clamps. That should fix the CEL. You will need to support the downpipe as it has flexpipe at the top.
Do not throw away that cat back!
Disclaimer: I never ran with the open downpipe’s but with NPP hooked up I could tell a noticeable difference in sound with a secondary cat delete.
Pic of my modified cats before I did longtubes
Roto-fab big gulp, Nick Williams 102mm TB, Kong X-port LSA, Ported 821 heads, BTR stage 4 V2 pd cam, 416 CI bottom end, original block. TSP 2” long tubes, Corsa ZL-1 catback. Nitrous Outlet 102mm plate kit/100 shot JUST IN CASE. NGK BR7EF plugs with Taylor plug wires. DSX flex fuel kit, DSX aux pump, zl1 in tank. deatchwork 1000cc injectors. B&M deep trans pan, stock 6L90 converter, ZL1 diff 3.23 ratio. GM ground effects, T-Rex upper grill, Z/28 Spoiler, Forgestar F14s, 12” subwoofer, and custom paint matched interior.
Ashen L99 is offline   Reply With Quote
Old 10-29-2019, 08:50 AM   #13
SlingShot
SlingShot's Avatar
Drives: 2012 ZL1 - #670
All I can say is WTF were you thinking, bet it sounds like an old dump truck now. For some reason I take it you are very young...
Old 10-29-2019, 09:06 AM   #14
jeff657756
Drives: 2014 SS 1LE
lol
jeff657756 is offline   Reply With Quote
