![]() Drives: 2012 Camaro 2LT Join Date: Oct 2019
Difference between CAI’s?
Is there really much of a difference in performance/sound between K&N, CAI inc, etc..? I bought the K&N 69 series Typhoon Intake and quickly regretting it seeing everyone prefers CAI inc.
![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2012 2SS/RS, 1968 SS Join Date: Feb 2012
Biggest difference is going to be how well each one actually gets you cold air. Most K&N kits let in a lot of hot air.
Best way is to monitor your IAT temps and see what the intake temperatures are. The cooler the better.
LS3 Crate Engine Swap | CSP Custom Cam 232/240 .615/.615 113 +3 | Stainless Power LT Headers | Z28 Intake | Borla S-Type Exhaust | FTI Triple-Disc Billet 3200 Stall
2012 Camaro 2SS/RS | 1968 Camaro SS | 2020 Cadillac CT5 Premium Luxury | 2021 Spark LS |
![]() Drives: 2011 Camaro 2LT Join Date: Oct 2018
Not sure if you sought yet, but somebody did a comprehensive test of the different brand CAI’s (The posting has a nice Excel spreadsheet you can open to see the results ). The CAI brand definitely showed the most average horsepower and torque gain, along with maximum gains. That being said, I bought the Roto fab kit and noticed a difference between that and stock intake.Happy shopping!
![]() ![]() ![]() ![]() ![]() Drives: 2013 SW 2LT/RS LFX/AY6 Join Date: Feb 2013
Get an intake scoop (Phastek, JRE, Rotofab all have them off the top of my head). Instead of needing the intake to be sealed, just make it so any intake on the car breathes ambient air. EZ.
(I was always surprised the intakes weren't tested with an intake scoop in another test.)
![]() ![]() ![]() ![]() Drives: 2012 Victory Red LFX Join Date: Dec 2012
I'd love to see a test done with a stock intake and scoop.
There was a fella on here that built a ram air slash scoop and recorded some pretty good spreadsheet numbers IIRC. Think he was talking about selling them too. Banned for it maybe?
'18 SS wheels, colored matched Heritage grille, actual driving lights, ZL1 strut tower brace, GM Performance billet aluminum fuel door, victory red rotors and calipers, 1/4 window American flags, splash guards, AEM dry panel air filter, Hot Wheels steering wheel and seat covers, Hot Wheels exterior emblems.
#6 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2011 1LT/RS A6 RJT SuperCharged Join Date: Mar 2011
The Vararam gave a noticeable performance gain when I had one installed.
BMR sub frame brace, BMR tunnel brace, LSR sways, LSR CM ca & tl, Sphon ExD el, GM tower brace, Megan EZ Streets, Goodridge Stainless Steel Braided brake lines, PowerStop D/S rotors & pads, Doug Thorty Ceramic Shorties, Magnaflow x-pipe, MRT V2.0, KICKER PowerStage sub & amp, Infinity speakers & tweeters, Viteese Throttle Controller, Viteese Paddle Shifters, ACS T2 Splitter, ACS T2 Ports/Quad LED lights, VDI kit, Havoc diffuser, IPF ECU/TRANS tuned, IPF/KPE Supercharged. 364RWHP/297RWTQ |
#7 | ||
![]() Drives: 2013 ZL1 A6 Camaro Join Date: Jun 2013
VARARAM intake and New Era over the radiator are the best if you are not going to use a race scoop ( V8 Guys ) In most of the pictures I see of air intakes, the intake tube is poorly designed and either sits right on the radiator heater hose and that temperature transfers to the MAF or is within a 1/2 inch of the MAF. Not as big as a factor in the V6 line since their intake air temperature table is zero'd out and doesn't pull timing, but the V8 line it does factor in. Just because the VARARAM doesnt dyno the best, doesnt me its not the best. If you understand how it works, you'll understand why you want it. Pretty in the engine bay doesnt make you faster. True cold air does.
2013 ZL1 Camaro A6. ARH Headers, K&N intake, Tuned by Tampa Tuning
2014 V6 Camaro bolt ons and E85 Tuned by Tampa Tuning |
#8 |
Instagram: Sangstah
Once I added the ADM scoop, even with my K&N Blackhawk intake, the IAT temps stay fairly close to outside ambient temp. The scoop is a big plus!
#9 | |
It don’t come easy.
Exactly what I did. And I know the air is getting to the filter because there are way more bugs to remove than w/o the scoop.
#10 |
SHKE BKE
Drives: 2013 Camaro Join Date: May 2014
#11 |
![]() Drives: 2013 v6 auto 1LT Join Date: Oct 2012
i have the scoop installed on my 2013 question what would be the downside to cutting the bottom out of my stock air box
#12 |
Honestly I haven't been in there to look but as long as it's not pulling any air from the engine compartment I don't see any problems. I'm running a washable high filtration dry panel filter already and want to add the scoop along with a Jacfab Laminator FX to increase intake flow.
