Old 10-30-2019, 08:36 PM   #1
SS Performance
SS Performance's Avatar
Drives: 02 Camaro B4C
Need clutch recommendations
I'm building a dedicated track car, https://www.camaro5.com/forums/showthread.php?t=555440.
The car currently has a A6 but I plan to switch to a M6. I am most likely going to use the TR6060 out of a ZL1.
My motor is a LS2 bored and stroked using a LSX454 rotating assembly, LS7 heads, Holley Hi-Ram intake and Brian Tooley cam. I expect to be making 700+ hp and will be keeping the RPM's under 7000.
I am not sure what clutch would be best. I can go with a stock clutch for the ZL1 or aftermarket like the McLeod RST, or something else.
I was wondering what others are using and what their experiences are.
Thanks
Craig
A man's garage is his castle
1969 Camaro SS
1970 Camaro SS
2002 Camaro B4C
2014 Camaro SS Dedicated Track Car
2015 Camaro 1SS 1LE
2008 HHR SS
1996 Silverado Crew Cab Long Bed Dual Rear Wheel
SS Performance is offline   Reply With Quote
Old 11-06-2019, 02:32 PM   #2
JDP Motorsports
JDP Motorsports's Avatar
Drives: 2011 Camaro SS/ 2016 Camaro SS
Thanks
Craig
Hi Craig,
I would highly recommend a Centerforce DYAD for your track car project.
The DYAD XDS is a great choice. It is a dual disc capable of supporting 1600 ft/lbs. of torque. The XDS is a little more aggressive with less dampening than the DS version.
You can find them listed on our website here:
https://store.jdpmotorsports.com/col...l-kit-08614842
Kind regards,
Stephen Komlos
JDP Motorsports
JDP Motorsports is offline   Reply With Quote
Old 12-13-2019, 07:15 PM   #3
Quicksilver 1LE
Quicksilver 1LE's Avatar
Drives: 14 1000HP SS/RS 1LE
I’m over a 1,000 to the rw and I just destroyed a Spec triple disc rated for 1500hp, so I would not use Spec. RPS seems to be the way to go according to my builder. Very light weight and will hold up to 2,000 hp. I used a Monster twin disc when I was at 800hp and it did great, so that is another clutch to look at for you.
Quicksilver 1LE is offline   Reply With Quote
Old 12-13-2019, 08:26 PM   #4
dreksnot
Served USN - Atomic Chimp
dreksnot's Avatar
Drives: 2021 Camaro ZL1 1LE A10 (stock)
I usually overkill and over-research things. I'd go either RPS twin/triple or Monster twin/triple myself. I've heard decent feedback on the McLeod RXT 1200 but I've also heard some Specs being, well, particular. Haven't paid attention to the other brands.
> Past Builds: 2013 Twin-Turbo LSX434 M6 - 1,359rwhp daily
dreksnot is offline   Reply With Quote
Old 12-20-2019, 09:57 PM   #5
oldman14ss
Drives: 2014 1ss camaro
ive had 2 monsters in my 4th gen with the tic master and speed bleed. all treated me well. not the level of hp you guys are creating but very reliable in my applications and I dumped the clutch a lot.
oldman14ss is offline   Reply With Quote
