Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Marketplace > Sponsors Classifieds Marketplace > Miscellaneous Items
Old 11-01-2019, 11:01 AM   #1
PFYC
PFYC's Avatar
Drives: Yes
Pedal Commander Throttle Response Controller for 2010-2015 Camaro
https://www.pfyc.com/pedal-commander...15-camaro.html
FREE SHIPPING in the Lower 48 states! Half price shipping to Canada.
PFYC is offline   Reply With Quote
Old 11-15-2019, 12:50 PM   #2
PFYC
PFYC's Avatar
Drives: Yes
Get the power of your Camaro the moment you press the pedal to the floor by adding the Pedal Commander Throttle Response Controller for 2010-2015 Camaro Eliminates Delay. Nowadays, vehicles are notorious for their delayed throttle response. That's where the Pedal Commander comes in. These days, vehicles use a drive-by-wire system that monitors the position of the gas pedal to control the throttle electronically, similar to a dimmer switch. The problem with this setup is that the signal from the pedal has to first be sent the ECU, which in turn then sends the signal to the actuator motor that controls the throttle body itself. This delay is most noticeable when trying to speed up to merge with fast moving traffic or pass a slower moving car. However, the Pedal Commander Bluetooth Throttle Response Controller will eliminate that delayed throttled response, giving your vehicle a drastic night and day difference in performance. Four Adjustable Control Modes. Unlike other throttle control devices that are either on or off, the Pedal Commander comes with 4 control modes: Eco, City, Sport and Sport +. Best of all, each mode has an additional 8 different levels of sensitivity which allows you to personally adjust each mode to your own personal driving style and needs. Switching between modes can be done manually on the Commander or can also be done using your smartphone (Pedal Commander App), without having to bend over and physically touch the Pedal Commander. Compatible with Aftermarket Programmers. The Pedal Commander can be used in conjunction with common aftermarket OBD-II programmers and/or monitors such as: SCT, Diablosport, Hypertech, Superchips, Bully Dog, and Edge. 2-Year Product Warranty. Pedal Commander manufactures their Bluetooth Throttle Response Controller to the highest quality and standards with CE and TUV Certification. However in the event you do receive a defective or malfunctioning device, Pedal Commander will replace it free of charge within 2 years of the original purchase date. Easy Plug & Play Installation. The Pedal Commander Throttle Response Controller connects directly into the stock throttle position sensor found on the drive-by-wire gas pedal using an OEM style plug and play connector with no permanent modifications required. The Pedal Commander is 100% reversible making it warranty friendly.
Application
2010 2011 2012 2013 2014 2015 Camaro
Old 03-26-2020, 08:13 AM   #3
PFYC
PFYC's Avatar
Drives: Yes
Old 03-26-2020, 10:31 PM   #4
'10CamaroDude
Drives: 2010 Camaro LS
Free version:
Tie to shoe, done.
'10CamaroDude is offline   Reply With Quote
Old 06-24-2020, 08:52 AM   #5
PFYC
PFYC's Avatar
Drives: Yes
Order yours today!!
Old 06-24-2020, 09:17 AM   #6
Bigdumogre
Bigdumogre's Avatar
Drives: 2012 Camaro SS
What is the benefit to this version over all the other ones that are around $79 like soler performance?
2012 Camaro 2SS/RS - CSP Custom Cam 232/240 .615/.615 113 +3, Texas speed CNC heads, FTI billet triple disc converter, K&N cai, Katech ported TB, GPI Ported/rod modded manifold, Texas speed 1 7/8 headers, HFC, Flowmaster 2 chambers with x pipe, Mishimoto CC, MSD wires, Roto fab washer relocation, tru cool 40k trans cooler, apex scoop, Pedders extreme coil overs and much more!!
Bigdumogre is offline   Reply With Quote
Old 08-20-2020, 08:48 AM   #7
PFYC
PFYC's Avatar
Drives: Yes
blue tooth, and the ability to manage it from your phone.
Old 11-09-2020, 06:55 PM   #8
SuperSportCamaro
Banned
Drives: chevy
I got a similar one made by Soler on my 17' SS. My camaro was already fast. But now it feels exactly like a direct throttle cable to carburetor setups of old. I can actually blip it right off idle. Mine is a 6 speed manual. Whatever you give the pedal it responds instantly with out that mushy laggy feel.
SuperSportCamaro is offline   Reply With Quote
Old 11-08-2021, 03:49 PM   #9
George-CZ
George-CZ's Avatar
Drives: 2010 2SS LS3 and 1978 STROKER 383
This is a good thing.
This and removing the OEM spring from the clutch pedal.
2 modes that have incredibly moved control car for the better.
My life is a constant struggle with Camaro.
K&N CAI, Stainless Power longtubes, high flow cats, modified Ragazzon High Performance axle back, Soler Performance ported throttle body, Soler Performance throttle controller, RAM clutch adjuster, modified LS7 clutch kit, Tick Performance billet bearing support, Tick Performance remote bleeder, separate clutch reservoir, BMR trailing arms, BMR toe rods, Pedders Suspension cradle bushing inserts, Control Arm Bushings, Strut tower brace, oil catch can, Hurst T-handle shifter, 20mm wheel spacers, DBA brakes, QTP Cutouts, Dynosteve tune.
George-CZ is offline   Reply With Quote
Old 11-10-2021, 08:34 AM   #10
PFYC
PFYC's Avatar
Drives: Yes
Order yours today!!
Old 06-30-2022, 12:33 PM   #11
PFYC
PFYC's Avatar
Drives: Yes
Old 08-23-2022, 03:54 PM   #12
PFYC
PFYC's Avatar
Drives: Yes
Thank You for shopping at https://www.pfyc.com/pedal-commander...15-camaro.html
