Old 12-14-2009, 08:07 AM   #1
Standard
Drives: 2023 ZL1 M6, 2010 SS M6
Lug nut torque - any consensus?
http://www.camaro5.com/forums/showth...ght=nut+torque
The manual says 140 foot pounds; but people mention other GM docs that claim 100 foot pounds, and references to the manual being in error.
Which is it?
I'm putting on some lug nuts, want to get it all resolved.
Standard is offline   Reply With Quote
Old 12-14-2009, 09:27 AM   #2
Sir Nuke
Master of All Things
Sir Nuke's Avatar
Drives: '26 Corvette Stingray
unless you are actually going to use a torque wrench, its not that critical. get yourself a long handled socket wrench or a +wrench and tighten them down evenly anbd tight......and you will be good to go.
Old 12-14-2009, 09:30 AM   #3
marley.
OCD
marley.'s Avatar
Drives: 2014 2SS/RS 1LE
When i ownerd my Charger if I was even 10 lbs under the torque specified in the manual my aftermarkets wheels made a horrible popping sound because they were moving on the studs. When I get my wheels in for the Camaro I will be tightening them to whatever the manual says.
marley. is offline   Reply With Quote
Old 12-14-2009, 09:34 AM   #4
Standard
You bet your *** I use a torque wrench! - so what's the torque to use, 100 or 140 foot pounds?
Old 12-14-2009, 10:32 AM   #5
69rsss383
69rsss383's Avatar
Drives: Corvettes, Camaros, Chevelles
It's 100 ft/lbs according to a local Chevy service manager. Metric is 140 Newton Meters. Many torque wrenches have both reading on them.
2010 2SS/RS, SIM, Pedders coilovers & bushings, Hotchkis sway bars & chassis braces, Corsa cat back, DT shorties, ADM Race CAI, VMax CNC TB, Jannetty Racing tune.
69rsss383 is offline   Reply With Quote
Old 12-14-2009, 10:33 AM   #6
8ty8 ls1
Resident Engineer
8ty8 ls1's Avatar
Drives: 2010 Camaro SS, 1988 GMC S-15
yes 100 ft/lbs.
12.68 @ 109: LSR cai, Borla S-type axle-back, Tunes
8ty8 ls1 is offline   Reply With Quote
Old 12-14-2009, 10:55 AM   #7
HeavyD
HeavyD's Avatar
Drives: 1SSRS RY L99
Ok, the torque is 140 foot pounds, or 190 Newton Meters - end of story!
Don't go by "general" or "standard" torques. Read the fine print in most of those guides, they alway say to torque to factory specs.
The Camaro uses 14mm x1.50 stud. The GM spec for this is 140 ftlbs, or 190 N.m.
Chev Traverse, 14mm x 1.50 spec from manual - 140 ftlbs / 190 N.m
Chev Suburban 1/2 ton, 14mm x 1.50 spec from manual - 140 ftlbs / 190 N.m
Chev Silverado 1/2 ton, 14mm x 1.50 spec from manual - 140 ftlbs / 190 N.m
Chev Express van, 14mm x 1.50 spec from manual - 140 ftlbs / 190 N.m
Ok, GM vehicles that have the torque spec of 100 ftlbs / 140 N.m are cars that use the SMALLER 12mm x1.50 stud. This includes the Corvette! Seriously, the Camaro is a big heavy car! It does rank up there with the trucks. The Camaro is the only car that uses the 14mm x 1.50 stud. All other GM cars use the smaller 12mm x 1.5 stud. Look at the Camaro wheel against one from a Colbolt! They are night and day different in size!!!! Why would you think the big Camaro wheel would torque the same as a little Colbolt wheel?
HeavyD is offline   Reply With Quote
Old 12-14-2009, 12:28 PM   #8
skuttduck
skuttduck's Avatar
Drives: 2010 RJT 2LT Camaro
Send a message via ICQ to skuttduck Send a message via AIM to skuttduck Send a message via Yahoo to skuttduck
Agreed.
Also keep in mind that when you go looking for tires, such as the Pirelli scorpions, you find them in the SUV section. This makes sense to me that you would have to torque them down as much as an SUV, if they are SUV size tires and lugs.
skuttduck is offline   Reply With Quote
Old 12-14-2009, 06:30 PM   #9
Sir Nuke
Sir Nuke's Avatar
WELL, the answer is below......read on.
Old 12-14-2009, 07:49 PM   #10
10redrocket
Drives: 2SS Camaro LS3
Always use a torque wrench. If you have someone else working on your car insist that they use a torque wrench. If they don't have one, get out of there.
Torque sticks? Your call but I wouldn't.
RECEIVED 5/22/09 - 2SS, SIM with CGM stripes, Black Leather, Polished 20's, Sunroof, LS3.
Past Rides: 69 Camaro RS Small Block
67 Chevelle SS Big Block
05 Cobalt SS Supercharged
07 Cobalt SS Supercharged
10 Camaro 2SS LS3
Soon: 18 Camaro 2SS 1LE
10redrocket is offline   Reply With Quote
Old 12-15-2009, 10:14 AM   #11
Standard
Thanks - expressed in terms of the studs, I am now confident in the 140 ftlbs torque.
And to restate, yes, I will only put them on with a torque wrench.
I was so anal about that with my prior car that I'd roll around on drag radials + spare fronts, then install the newly shod wheels myself.
Old 12-17-2009, 11:30 AM   #12
CamaroSpike23
Truth Enforcer
CamaroSpike23's Avatar
also, after 50-100 miles, recheck the torque on the lug nuts.
I piss excellence
and fart awesomeness
Old 12-19-2009, 01:51 PM   #13
mickss
mickss's Avatar
Drives: 2010 Camaro LS-M6 67 Chevelle Wgn
There is one other thing regarding lug nut torque values. Unevenly torqued wheels will warp your brake rotors. If you let who ever or where ever you have your wheels mounted use an impact gun you do so at your own risk. Some will say it`s OK to use an impact gun, others will not, me i`m in the torque wrench camp. As for shops that use torque sticks you should recheck your lugs with a torque wrench.
mickss is offline   Reply With Quote
Old 12-20-2009, 08:51 AM   #14
HeavyD
HeavyD's Avatar
Yah, that's true. If you watch a tech install your wheels with an impact gun and then use a torque wrench, if the torque wrench clicks right away then the nut is overtorqued! It is ok to snug up the nuts with a gun, but they all need to turn a bit more with the torque wrench to make sure they are properly tightened! Impact gun could have no problem crushing the nuts to 200 ft lbs. If you put your torque wrench on it, it will click and not move. All you know is the nut is torqued to at LEAST 140 ftlbs.
Lug Nut Torque Z\28Kid Wheels and Tires Talk Sponsored by The Tire Rack 76 12-27-2015 04:38 PM
Torque Converters CamaroSpike23 V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 48 08-16-2014 03:07 AM
Horsepower V.S. Torque Milk 1027 Wiki 0 09-15-2009 12:19 AM
horsepower vs torque zebra Dragstrip and Launch Techniques Discussion 35 09-09-2009 09:26 PM
Chrome trim rings and lug nut covers LS Angrybird 12 Cosmetics and Lighting Modification Discussions 7 02-24-2009 02:59 PM
