Old 11-02-2019, 02:31 AM   #1
iDivinst
Drives: 2012 Camaro 2LT
2012 LFX Exhaust
Since I can’t have headers, which exhaust system would you guys recommend for the best sound quality? (Without terrible drone)
iDivinst is offline   Reply With Quote
Old 11-02-2019, 03:15 AM   #2
SIM GhostrdrZ
SIM GhostrdrZ's Avatar
Drives: ‘14 ZL1 M6 vert
Corsa catback. Period.
SIM GhostrdrZ is offline   Reply With Quote
Old 11-02-2019, 03:26 AM   #3
iDivinst
Which size and tip?
Old 11-02-2019, 10:26 AM   #4
DSX_Camaro
DSX_Camaro's Avatar
Drives: 2013 SW 2LT/RS LFX/AY6
If you aren't subject to emissions testing you can still get high flow cat pipes or catless downpipes, which will still net more power and volume.
The cheapest go to is usually adding a Magnaflow 11386 X muffler in place of the stock H and then muffler delete. Good tone, not too much drone. Using any axle back will keep the volume down. MRT v2, Solo MR resonators, Magnaflow / Corsa / Borla mufflers. You have options.
DSX_Camaro is offline   Reply With Quote
Old 11-02-2019, 04:17 PM   #5
iDivinst
I’m thinking MRT 2, Resonator X Pipe, and either hfc or downpipes.
Old 11-03-2019, 11:48 AM   #6
DSX_Camaro
DSX_Camaro's Avatar
Tried and true.
