Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Marketplace > Sponsors Classifieds Marketplace > Miscellaneous Items
Old 11-05-2019, 12:19 PM   #1
PFYC
PFYC's Avatar
Drives: Yes
New Products and Specials at PFYC!
Pedal Commander Throttle Response Controller for 2010-2015 Camaro
https://www.pfyc.com/pedal-commander...15-camaro.html
Get the power of your Camaro the moment you press the pedal to the floor by adding the Pedal Commander Throttle Response Controller for 2010-2015 Camaro Eliminates Delay. Nowadays, vehicles are notorious for their delayed throttle response. That's where the Pedal Commander comes in. These days, vehicles use a drive-by-wire system that monitors the position of the gas pedal to control the throttle electronically, similar to a dimmer switch. The problem with this setup is that the signal from the pedal has to first be sent the ECU, which in turn then sends the signal to the actuator motor that controls the throttle body itself. This delay is most noticeable when trying to speed up to merge with fast moving traffic or pass a slower moving car. However, the Pedal Commander Bluetooth Throttle Response Controller will eliminate that delayed throttled response, giving your vehicle a drastic night and day difference in performance. Four Adjustable Control Modes. Unlike other throttle control devices that are either on or off, the Pedal Commander comes with 4 control modes: Eco, City, Sport and Sport +. Best of all, each mode has an additional 8 different levels of sensitivity which allows you to personally adjust each mode to your own personal driving style and needs. Switching between modes can be done manually on the Commander or can also be done using your smartphone (Pedal Commander App), without having to bend over and physically touch the Pedal Commander. Compatible with Aftermarket Programmers. The Pedal Commander can be used in conjunction with common aftermarket OBD-II programmers and/or monitors such as: SCT, Diablosport, Hypertech, Superchips, Bully Dog, and Edge. 2-Year Product Warranty. Pedal Commander manufactures their Bluetooth Throttle Response Controller to the highest quality and standards with CE and TUV Certification. However in the event you do receive a defective or malfunctioning device, Pedal Commander will replace it free of charge within 2 years of the original purchase date. Easy Plug & Play Installation. The Pedal Commander Throttle Response Controller connects directly into the stock throttle position sensor found on the drive-by-wire gas pedal using an OEM style plug and play connector with no permanent modifications required. The Pedal Commander is 100% reversible making it warranty friendly.
Application
2010 2011 2012 2013 2014 2015 Camaro
FREE SHIPPING in the Lower 48 states! Half price shipping to Canada.
Single Stripe Stripe Kit for 2009 2010 2011 2012 2013 2014 2015 Camaro
https://www.pfyc.com/CA1218.html
Make your Camaro look even meaner with this Single Stripe stripe kit. This kit is cut specifically for 5th gen Camaros and is sure to turn heads. Made of 3M or Avery 2 mil high performance vinyl film, each piece is precut to fit the Camaro and requires no cutting on the vehicle. Please note that we have seen inconsistencies with Avery, so we highly suggest choosing 3M colors
Shipping Note: The standard colors of Matte Black, Gloss Black, Silver Metallic, and Bright White are kept in stock and ship right away, but other colors will take up to 3 business days to ship after you order.
Application
2009 2010 2011 2012 2013 2014 2015 Chevrolet Camaro (all models)
2014 Chevrolet Camaro SS
S-Sport Stripe Kit for 2014 2015 Camaro SS
https://www.pfyc.com/CA1217.html
Give your Camaro SS a hot look with this S-Sport Stripe kit. Made of 3M or Avery 2 mil high performance vinyl film, each piece is precut to fit the Camaro and requires no cutting on the vehicle. Please note that we have seen inconsistencies with Avery, so we highly suggest choosing 3M colors
Application
2014 2015 Camaro SS (will not fit V6)
R-Sport Rally Stripe Kit for 2010-2015 Gen5 Camaro
https://www.pfyc.com/CA1135.html
Designed specifically for the new Camaro bodylines, this 4-piece R-Sport Rally Vinyl Graphics kit offers aggressive styling and a great retro look. Made of 3M or Avery 2 mil high performance vinyl film, each piece is precut to fit the Camaro and requires no cutting on the vehicle. Please note that we have seen inconsistencies with Avery, so we highly suggest choosing 3M colors. The rear deck stripe fits Camaros with or without a spoiler.
Shipping Note: The standard colors of Matte Black, Gloss Black, Silver Metallic, and Bright White are kept in stock and ship right away, but other colors and carbon fiber will take up to 3 business days to ship after you order.
Application
2009 2010 2011 2012 2013 2014 2015 Camaro LT LS SS Coupe or Convertible
Does NOT fit 2014-2015 V8 Camaro
Hood Badges for 2010-2015 Camaro LS3 426HP
Show off your incredibly horsepower numbers that sit directly underneath with these 426hp badges. These badges are sold as a set and simply peel and stick into place. 3M adhesive built into the backing makes installation a snap. These badges feature the 426HP and LS3 numbers as shown.
Application
2010 Camaro
2011 Camaro
2012 Camaro
2013 Camaro
2014 Camaro
2015 Camaro
Sinister Camaro Ram Air Hood for 2010-2013 Camaro
https://www.pfyc.com/sinister-camaro...13-camaro.html
On our Sinister Camaro Ram Air Hood, note the shapes and lines of the cowl follow the original design of the factory hood, adding to the aggressiveness while retaining a consistent appearance. The location and shape of the intake scoop is carefully placed, lining up with the lines of the fender and front fascia. The upper leading edge of the scoop includes a design element found along the leading edges of the front fascia. These are just a few of the subtle details that sets it apart. The Sinister Camaro Ram Air Hood conforms as a natural part of an already incredible automotive design, not as an afterthought.
The Sinister Camaro components are born from the belief that function and form should integrate seamlessly with the elements of design already present. Each line, radius and element of the Sinister Camaro components has been carefully crafted to enhance what the original design engineers sculpted.
The Sinister Camaro Ram Air Hood offers functional flow to the air intake along with functional heat extraction from the engine bay. Utilizing the factory windshield washer assembly, hinges and hood strut, the Sinister Camaro Ram Air Hood is ready for prep and paint and uses the factory latch and bump stops. The included front grill is removable and the hood is designed to accommodate other custom or aftermarket grills as they may become available.
Want more information? Read our blog post titled Give Your Camaro a Sinister Look. Click here for all you need to know.
Currently available in fiberglass or carbon fiber.
Application
2010 2011 2012 2013 Camaro all models
2014-2015 Camaro V6
Does not fit 2014-2015 V8
PFYC is offline   Reply With Quote
Old 10-07-2022, 01:50 AM   #2
PFYC
PFYC's Avatar
Drives: Yes
